Buying Finish Mower - 6ft vs. 5ft.
   / Buying Finish Mower - 6ft vs. 5ft. #1
Anonymous Poster
Epic Contributor
Would like some feedback on size of a finish mower... Looking at buying a First Choice Finish Mower... Tractor is 25 HP rated engine - 21 HP at the PTO and am told this should power the 6ft finish mower OK as long as I stay out of the tall stuff... I have about 4 acres to cut..... 1 acre in fescue( the yard) and about 3 acres in native grasses that I cut every other week or so.... Was doing this previously with a large Lawn and Garden 42 inch cut (took me forever when I did the whole thing), that finally broke and I upgraded to a compact.... I have 160 lbs. of suitcase weights on the front currently and can add an additional 80 lbs. so, I think I can counter balance the larger 6ft mower.... My question is, does the 6ft. hinder you in any great way in terms of mobility... I have a few trees to go around, but not excessive... I hear that the 6ft is even better in terms of being able to stay away from some objects.. Welcome any comments for feedback based on experiences....Thanks in advance.....
   / Buying Finish Mower - 6ft vs. 5ft. #2
I run a King Kutter 5 footer on my JD 4100. I have no problems and feel like I could run a 6 footer horsepower wise, would be heavy though. Mobility is fine, I would expect a 6 footer wouldn't be much different than a 5. I would think your real choice would be between 6 foot and 7 foot (do they make 7 foot finish mowers?).
Good luck
   / Buying Finish Mower - 6ft vs. 5ft. #3
They do make 7 ft finish mowers. A 7ft mower really jumps up in weight, they also scalp or miss alot more unless you have really flat areas to cut. Kioti sells a 7ft rear discharge one as well as some other brands. The problem with King Kutter F-M's is they are very heavy for their size of cut, not bad mowers just heavy. You can buy a different brand mower and have just as good a mower but not as heavy, for about the same money. Weight is a killer on an F-M. It's hard on spindles etc.
Ob1
   / Buying Finish Mower - 6ft vs. 5ft. #4
I have a Woods 7' rear discharge mower and I couldn't be happier. I had a JD 216 lawn tractor w/46" deck, it cuts at least twice as well in addition to the almost double the cut. No streaks from the tractor tires crushing the grass, no scapling, (it rides on 4 wheels and has a roller in front) and it mulchs leaves like mad. If you have the hp and the room, I hardily recommend them.
Nick
I currently run a King Kutter 6' deck. I moved up from a 5' and saves alot of time. I mow @ 8 acres of lawn and pasture. The KK is well made and priced pretty good compared to some others. I have been told that they do make a 7' model, and that will probably be my next one. To answer your questions; No big concerns moving from a 5' to a 6' model. Your horsepower should be able to handle all but real high or thick areas, but those can be done with a second pass. You'll save alot of time with the larger deck.
   / Buying Finish Mower - 6ft vs. 5ft. #6
Go with the 6', you'll be glad you did. What will you do with all your time now? I remember
those days of mowing the field with the 48" mower. Never seemed to get done. Have fun.
Thanks to all in helping me make my decision... I have decided on the 6 FT rear discharge... Looks like the mower to go with based on the feedback and versatility compared to belly mount and the smaller 5 ft......... Appreciate the advice!!
   / Buying Finish Mower - 6ft vs. 5ft. #8
Hey Surge,
I didn't know you were considering a belly mower. That is what I have on my JD 955.
I really like it alot more than a rear mower. A rear mower may be better for you.
Ron,
Belly mower was never really in serious running as of late as I have no mid-mount PTO.. and the cost is more for say a Woods... I would also have to jury-rig a power transfer off the rear PTO... Then again the ease of cleaning and removing the rear deck was very appealing ... However, that all being said, I still think a belly mount has more manuverability and easier to handle, at least in most open spaces... So, I think you are right, rear mower is probably more up my alley.... Thanks for the feedback .....
   / Buying Finish Mower - 6ft vs. 5ft. #10
I realize you've already made the decision to go with the 6' mower, but there is one more thing to consider that I didn't see mentioned. If your ground is fairly flat, then you should be fine with the 6' deck. But, if you have hills, you might have trouble handling a 6' deck and could even be a little short on HP going up hill. I have a TC29D and need 4WD in a couple places to make it up the hills with my 6’ mower.
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2001 Kubota L3010 (A50123)
2001 Kubota L3010...
