Buying discontinued models
   / Buying discontinued models #1
jmaine
Hi guys, I've been looking at used Kubota tractors in the 35 to 45 horsepower range. Several that I've looked at are discountinued models. Is there any danger in buying a discontinued model? Does Kubota do a good job of stocking parts for older models? My concern is parts availability; I don't want a situation where I need a part that's unique to my particular tractor and said part isn't readily available or if it is, it's expensive.
Are there particular models that I should avoid? Maybe Kubota has discontinued certain models due to reliability/maintenance issues?
Thanks
Joe
   / Buying discontinued models #2
I wouldn't worry about anything thats 10 - 15 years old. Kubota uses a design for years with only minor changes (decals, sheetmetal,etc.). They seem very well supported with parts..... even on very old models. Only thing i might be concerned with is that it already has a loader and backhoe if you ever plan to add one. Thats the only area where outfitting an older tractor can get expensive.
   / Buying discontinued models #3
Thanks
Joe
If it is any comfort to you, a few years back I restored a 1973 L210. This is a very early import. During the restoration process, I ordered many, many parts. Right now, I would be hard pressed to remember any part that wasn't available. I'm not saying there may not be something that is no longer available, but Kubota seems to do a really good job with parts availability for the older tractors. As Ductape stated, I would be more concerned about the availability of add-ons, like loaders and such.
   / Buying discontinued models #4
Since you are looking at models larger then a BX then I wont have to say stay away from 50 series due to jerking of tranny ;). But regardless of any model- tractor parts are more readily available to order much easier then a car or truck. So no worries there .:cool:
   / Buying discontinued models #5
I have to agree with everyone. Kubota does a good job at stocking parts for older tractors. I recently had to order a grill for a 1987 L2550. It took less than a week for the exact replacement to arrive at the dealer's. I will also agree that it would be difficult, or impossible, to find a complete new loader or backhoe for a very old machine. You may find a used one if you look hard enough. Three point implements are not an issue and long as you have a Cat 1 or 2 Three point hitch and 540 RPM rear PTO.
Great, thanks for the information guys, it's appreciated.
Joe
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
Pallet of miscellaneous chains  (A52384)
Pallet of...
2001 John Deere M665 (A50120)
2001 John Deere...
Used 20' Container Box  (A52384)
Used 20' Container...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
