Buying Blues* used NHTC40
   / Buying Blues* used NHTC40 #1
easttexas
Palestine, TX
NH TC40 ......I hope
Want to buy my first tractor, is this a good value?
Should cover all my needs from what I've researched, but know nothing about NH. Any known problems with this model?
What about price?
03 New Holland TC40 4wd /synchroshuttle w/16LA FEL
Its an 03 with 375hrs
Includes
Wide loaded R4s
skid steer quick attach on the FEL
FOP canopy
6mnth drivetrain warranty
At $14,800 is it too good to pass . Looking at other new brands also
What about price?
Includes
Wide loaded R4s
FOP canopy
   / Buying Blues* used NHTC40 #3
Your price on that tractor is around $5000 less than the new price. With only 375 hours and set up with the QA loader, it sure sounds like a solid buy. Be sure to check the radiator/battery area. That's a standard thing on any brand of tractor you buy. The current style of putting batteries in front of the radiators invites problems with battery leakage and corrosion.
   / Buying Blues* used NHTC40 #4
   / Buying Blues* used NHTC40 #5
Thats a pretty good buy. Just make sure you check all the fluids and the clutch engages good.
   / Buying Blues* used NHTC40 #6
Thanks, I'm really having a hard time deciding between the price of the tc40 and spending 5k more on a new tractor that will give me clutchless operation and a full warranty.
I found a very small grinded spot on the metal dipstick in the rear Hydrolic fill. Dealer suggested it may have been attempt at marking the fluid range? Its on the side of the stick right at the fluid check level. moon shaped and about 1/2 long and just a mm or so deep.
Any opinion on what could have caused that, other than someone with a dremel or file?
I am calling the previous owner tonight to find out what the tractor was used for, if he marked the stick, and why he traded in on the same new tractor I've been considering.
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A51247)
UNUSED CFG...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 46 (A53084)
2020 JOHN DEERE...
PALLET OF GOLF CART TIRES (A51248)
PALLET OF GOLF...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
