Buying Advice Buying Backhoe. So many questions
   / Buying Backhoe. So many questions
Thanks for the advice. I guess I got lucky with my last machine. I bought it for $7000 and it was a great machine. A small commercial contractor owned it and he bought a new machine. Used it on many jobs over a 4 year period. House foundations with full basements, septic tanks and pools, grading, some demo, curbs, piping and lots of grading and material moving. Sprung a leak on the Hoe that I fixed and one stabilizer would drift to the ground that I repaired. I even got 2 buckets for the backhoe with it.
That was up in NY. Sold it before moving to SC. Looking around here I seem very limited. Back in NY there were dozens of machines +- 10K. Just had to week thru the crap. Thank for the advice
   / Buying Backhoe. So many questions #13
I bought a Ford 3400 with 10' hoe (then 16 years old) back in 1986.
It had been used as a cemetery machine (1350 hrs.).
Wanted a 13' hoe, but had looked for 2 years.
Paid $10,000 back in '86..... something 16 years old, and in similar condition today would probably cost $20,000+.
It is simply my play machine, and I love it.
Completely disassembled and painted it (CAT yellow) in 2016.
It is now 47 years old, and the best toy I have ever owned!
   / Buying Backhoe. So many questions #14
That kind of money will pay for a lot of rental. I suspect most people have a backhoe or excavator that sits 99% of the time.
True in my case. My 3 pt backhoe attachment sat most of the time. Now I have an excavator at 7x the cost that sits frequently, as well. I would not be without a digging machine, though. So nice to be able to jump on it for an hour and get something done that I otherwise would have to schedule, rent, pay, hope for good weather, etc.
And it's not like the machine depreciates quickly. I expect my excavator to be worth the same money or more in 10 years. I store indoors and it gets great maintenance and any needed repairs.
That is how I feel. I used my last machine so many times for small jobs that would be a burden to rent something. My last machine was sold for a few bucks more than what I paid for it. When I figure in repairs I probably broke even which is a bonus.. Granted If I was buying a 40k machine and financing it a rental may make more sense if it is parked most the time.
I have a few case 580 machines in my budget that I am going to look at since nobody could offer any other other machines and this is all I know and was happy with.
   / Buying Backhoe. So many questions #16
all 3 websites, make sure you enter zip code, to search by distance.
www.machinerytrader.com
www.tractorhouse.com
craigslist: chicago jobs, apartments, personals, for sale, services, community, and events
there are some other websites out there, that might list a TLB / construction equipment. for myself the other websites did not have enough listings on them to make them worth while. granted checking, you might find a deal.
for myself for the ford 555c TLB, i grabbed 12 or so TLB (tractor loader backhoes), off the internet, woke up early, and drove to all of them in a single day. some were complete junk. so loose, that you were waiting more for after you removed hand for lever for the backhoe and/or FEL to stop moving. (more so backhoe). others the tires were complete garbage. (tires cost), other had engine / hydrualic issues. a lot of them were leaking oil all over the place. some of them had larger engines in them and suppose to have more GPM and pressure in hydrualics, the smaller units were out powering them due to overall useage and abuse some of the bigger ones saw.
make sure you always go test drive the machine, no if's, and's, or but's. the difference can be huge!
dealer vs personal, most of the backhoes i came across were from dealers. though it can always change. i would personally not focus on dealer vs personal, and simply make sure you go test drive them. and then go from there.
some issues i found out by test driving....
--check the oils and fluids for it. before starting it up. to see the color
--pay attention to the exhaust as you start it up cold, and if any smoke and color of it.
--start it up, and then talk to whom ever, and let it run for a bit to warm it all up.
--operate everything FEL, backhoe, all gears, forward /backwards, split brakes, diff lock, lights, dig, back drag, enough to get all the warm oil into all the hoses and hydraulic cylinders.
--raise stuff up in the air and extend them out, and shut down tractor. and see how quickly they drop, a couple of them i tested out, dropped within a couple minutes, others barely moved, if at all.
--check fluids after shutting it down while waiting to see if stuff drops rapidly.
--check the battery/s is it old and corroded.
--check the fan belt on front of engine. the TLB i have, you darn near need to pull most of the front off to replace the belt. due to needing to get around the hydraulic pump and some other frame work.
--double check if there some sort of "cold package", from a block heater, to ether, to glow plugs, to other on unit.
--go over all the hydraulic hoses, some of them hoses i saw on machines i looked at, were right at about being cut into, or possibly leaking already.
some units were sloppy grease, were they been hit with grease and old stuff not wiped away with a rag, while others, look like there just washed :/ rather look at a muddy, greased, oil machine. to show were it has issues and what has been done. vs an unknown clean machine.
--you will most likely find transport lock for backhoe = broken / torn off / other wise destroyed.
--you will most likely find any cab, having missing windows, and busted out lights.
--again double check tread on tires, tires can be rather expensive for the larger rear tires.
--backhoe buckets, may make a difference for you....from say a wider 20 to 36" bucket for digging basements. to a smaller 10" or so trenching bucket.
--i would completely forgot trying to find a given "joystick / lever type" for backhoe. your getting used, and controls are all over the place, put good mechanical machine over, re-learning to use controls (at least for me)
find yourself a TLB first, then get a trailer/truck that can haul it.
   / Buying Backhoe. So many questions #17
I suggest that you buy directly from backhoe maker to save some amounts and to be sure with the the guarantee of quality.
   / Buying Backhoe. So many questions #18
Also check Iron Planet, I've seen lots of backhoes (usually Case) off rental with around 2,000 hours that auction off at about $20-25k. They provide a comprehensive mechanical evaluation of the unit. I bought a dozer from Iron Planet a few years ago and it was exactly as described. Happy buyer.
   / Buying Backhoe. So many questions #19
You really think the OP should buy "from the backhoe maker"?
The OP budget is 10-12K.
How is that going to happen?
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
Zero Turn Mower (A55853)
Zero Turn Mower...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
ASSET DESCRIPTIONS & CONDITION (A57880)
ASSET DESCRIPTIONS...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
