Buying an old JD, maybe 4040, Beginner questions
   / Buying an old JD, maybe 4040, Beginner questions #11
Often refer to moldboard plows as "having a certain number of bottoms" so no apology needed..
   / Buying an old JD, maybe 4040, Beginner questions #12
Ditto what beenthere stated.
   / Buying an old JD, maybe 4040, Beginner questions #13
In general, that 4 series tractors possibly were JD's most success.
But for your needs, you should be looking into utility range and not tow crop.
   / Buying an old JD, maybe 4040, Beginner questions #14
I disagree with you. Due to JD rowcrop tractors having superior designed/better operating/easier to repair hyd systems I'd choose RC model over Utility model especially where a higher HP utility with dry clutch/FEL is concerned. My opinion comes from serving as a JD dealer service manager for 13 yrs.
   / Buying an old JD, maybe 4040, Beginner questions #15
Jim, I do respect your contribution to this forum. You sure possibly know more about the Green Tractors than anybody else.
But what I would be steering the OP to is the old 5 Series. Apparently as bullet proof as the 4 but way more utility. In my opinion, the 4 is way overkill for the OP.
   / Buying an old JD, maybe 4040, Beginner questions #16
There’s really no question about that.
   / Buying an old JD, maybe 4040, Beginner questions #17
Bavarian
I also respect your opinion but Jared specifically stated [/quote]This has me looking at the old row crop tractors in the 85-100hp range[/quote] which JD 4030 & 4040 apply.
There are other members of this discussion forum that are as or more knowledgeable about JD tractors as I am BUT I probably more opinionated(vocal)
I agree JD 50 & 55 utility/rowcrop tractors are some of the better built tractors but utility hyd systems/ traction clutches won't warm up their rowcrop counterparts. There's no comparison in ease of operation of a tractor with a "flat operators station"(rowcrop) vs a "straddle operators station"(most utility models except higher HP models). I've owned a JD 4255 since Feb '93 & it's approaching 12,000 hours of use
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55314)
2020 Massey...
1999 CATERPILLAR 963C CRAWLER LOADER (A52707)
1999 CATERPILLAR...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
