Buying an L4850, any things to be aware of?
   / Buying an L4850, any things to be aware of? #1
Brambleberry
Kubota 4850 EverClutch
I think I've found the perfect tractor. It's a long ways away, but has everything I'm wanting and has been very well maintained.
L4850, 1997, 1938hrs, hydro shuttle shift, LA950A FEL, 4wd, 540/750pto, and a very fair price tag.
Any last thoughts before I make the deal?
Thanks everyone for all the help and details getting me to this point! I would have gone sideways many times without your input.
   / Buying an L4850, any things to be aware of? #2
So, did you buy this tractor or the GST?
Got the L4850! So far so good, but the power shuttle is taking a bit to get used to. Just have that strong instinct to clutch before moving any levers on a tractor 😬.
What sucks is that it didn't end up having the 2 speed PTO. The Everclutch models had just 540 with an optional 1000 add on.
Interestingly, the PTO doesn't seem to have a brake, I'm wondering if it has a built-in overrunning clutch. Trying to figure this out, will probably start a new thread over in the owning/maintaining forum.
Otherwise, this thing is a beast. Filled rear tires and also cast wheel weights! Tires are original R4s and need to be replaced soon. I think I'm going to just use the wheel weights instead of filling the tires. I'd like to switch to R1 ag tread but need to figure out if I need different rims for that.
Paid $17k for it, seemed like a fair price to me.
   / Buying an L4850, any things to be aware of? #6
You will need to change(all 4) rims to go to R1's.My PTO will run for a while after shutting off(bought new).Turn RPM's down first.
Do you have the same tractor as I do?
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
1629 (A57192)
1629 (A57192)
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
