Buying Advice: Rotary cutter for Kubota MX 5100
   / Buying Advice: Rotary cutter for Kubota MX 5100 #1
Dbplunk
East Texas
Kubota MX5100
A Kubota dealership near me suggests a 6' Land Pride RCR 18 series mower, for $3600-ish. I don't have that big of a farm and would be happy with a sturdy 5' mower, maybe even a 4 footer.
I'm primarily trying to keep the brush under control that sprouts up around my out-buildings, driveways, and fence lines. I'm getting older and would like to get something compatible with a "Quick-Hitch."
I'm scouring this forum, now, for previous questions like this, but thought I'd throw this out now. Thanks for any tips.
   / Buying Advice: Rotary cutter for Kubota MX 5100 #2
I have a LandPride 6 foot on my MX5200 and it works fine.
Andy
   / Buying Advice: Rotary cutter for Kubota MX 5100 #4
You won’t want anything smaller than 6’ behind an MX.
   / Buying Advice: Rotary cutter for Kubota MX 5100 #5
You don't want any smaller than a 6',I have one that is used with a L4240.
Hard part is the PTO ,not the three point.Service the slip clutch every spring.
   / Buying Advice: Rotary cutter for Kubota MX 5100 #6
Price sounds high. You can get a Brown 416 for not much more and it’s 1000 times better
   / Buying Advice: Rotary cutter for Kubota MX 5100 #7
How much acreage are you going to mow? One thing the forums is good at is spending other people’s money. Up until this year I mowed 50 acres with a 5’ landpride. Works fine.
   / Buying Advice: Rotary cutter for Kubota MX 5100 #8
Get a mower wider than the rear tires. If the mower is narrower than the tires you will never mow close to the fence line of ditch bank. I have a 7 ft offset flail mower on my MX5200. The offset mount kicks the mower over so it's about even with the left tire and sticking 10-12" past the right tire so I can mow close to fences, trees, the creek edge...whatever.
I use a Quick Attach. Similar but different. You may have to extend your toplink and PTO for the QA hitch.
   / Buying Advice: Rotary cutter for Kubota MX 5100 #9
This^^^^^^. But I don’t have a quick hitch and I get along fine. I love the telescoping lift arms.
   / Buying Advice: Rotary cutter for Kubota MX 5100 #10
Land Pride is 100% owned by Kubota. Have no concern about a new Land Pride rotary cutter being compatible with a Kubota tractor equipped with a new Land Pride Quick-Hitch.
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
377811 (A48836)
377811 (A48836)
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
