Buying a B6100 with a stuck transmission
   / Buying a B6100 with a stuck transmission #1
jtread
Gilroy
John Deere 322
I am looking to buy a B6100 but it seems to have a transmission problem. It is stuck in 1st gear. Actually, I believe it will shift between 1st and reverse, just not the higher gears. The owner claims it was working fine until he parked it (claims for 3 months.....), now it is stuck. It will shift in and out of 4 wheel drive as well as high/low.
Any thoughts on what might be happening here? I will go see it Sunday morning, is there anything I can look at without taking it apart? Is there anything else besides the transmission that I should be looking at before purchasing the tractor?
The owner seems open to giving the background info about the tractor so I should be able to get a good idea of what I'm getting into before throwing down the cash!
   / Buying a B6100 with a stuck transmission #2
It could be as simple as a shift fork being bent or a roll pin being out of place.
I was hoping that there was a common 'simple' problem like that, but I don't know the transmission well enough to be sure. Thanks.
   / Buying a B6100 with a stuck transmission #4
Could be the clutch rusted if it wasn't used for a while. On my 2620 there was a wood block that came with it to keep the clutch from being engaged if it were stored for any
Long time.
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
20' Sea Container (A50774)
20' Sea Container...
2017 Nissan Murano AWD SUV (A50324)
2017 Nissan Murano...
CATERPILLAR SKID STEER PALLET FORKS MAST (A51244)
CATERPILLAR SKID...
