Buying a 5310
/ Buying a 5310 #1
patton
Alabama and Georgia
JD 1050, Ford 4000
I'm planning on buying a new tractor, and believe I have it narrowed down to the JD 5310 with 3 SCV valves (2 on side and one in rear), MFWD, loader, telescoping draft links, R1 tires, and synchro tranmission.
I need 45 PTO hp minimum to pull a round bailer, but at 55 hp the 5310 gives 10 more hp then the 5210 (@45 PTO HP) at a minimal cost or increase in size. Other than that I will use it for tillage, bushhoging and misc. utility work.
I plan on buying the loader without a bucket and getting a 4 in 1 bucket, hence the third SCV valve, I can also use it to run a winch, or a implement with hydraulics while keeping the loader connected. I'm considering ordering a alternator off of the cab model to up the power available and mount 2 50 or 100 watt hella work lights facing forward. I have them on my truck and love them.
I'll probally add a fire extingusher, and may have the tires foam filled, I'm not sure. ($1000 for a pair of 13.6-28s, but it adds more weight than CaCl)
I can't decide on getting a canopy- nice in the fields, seems like a liability in the woods- an thoughts on this or anything else?
I also can't decide it the telescoping draft links are worth it- none of the demo models I have seen have the cotter pins pulled so you can try them out. I've never owned a tractor with them before, but I tried a set out on a Kuboda M series, that were well thought out (ie I would kill for them on any tractor that has its impliment changed more then once per year)
/ Buying a 5310 #2
I too looked at the 5210 and 5310 but I think they are out of my price range. They beat the FEL on the 5n05 Advantage series but I can't justify the price. I got a price from a dealer for a 5210, SynchShuttle, MFWD, 4n1 541 FEL, three SCVs, folding ROPs, and telescoping links for 23,547 for the tractor and another 6,000 for the FEL.
www.4turf.com listed a 5310 with MFWD at 25,795.
I just looked at the 4900/5700 Kubota M Tractors but according to their brochures these tractors can only use two SCVs. I need a three SCVs to handle the FEL, 4n1, and hydro toplink. Prices looked good but I really need three SCVs.
I'm waiting on some prices for a NH 55/65 tractors...
Hope this helps...
Dan McCarty
/ Buying a 5310 #3
Patton,
The telescopic links are worth it to me. If you are not planning on getting some type of quick-hitch device I think they are worth the money, about $200.
/ Buying a 5310 #4
The 5310 is a nice tractor...looked at that but ended up getting a 5410 which is only 10HP larger, but is actually a much larger and heavier machine. I am happy with it, but sometimes wish I also had a little 4wd machine (about 25-35hp) for manuevering in the smaller areas....
...anyway, the links are worth it. For a couple of hundred bucks they will pay for themselves in no time at all.
/ Buying a 5310
Wow, I can beat those prices. Local JD utility dealership had a 5210 for $21,000 with maybe 10 hours on it (never had an implement hitched. A guy I know got a quote arround $28,000 for a 5310 with the loader, 3 SCVs, links, canopy and synchro tranny. He did his homework and I benefit from the results. I think this one had a few hours on it as well. Other dealers were quoting maybe $500 higher.
As regards the Kubota M series, a dealer told me they were available with 3 valves- The literature says 2 on the open station, 3 on the cab model. Maybe it's just a ordering code issue, and the dealer knew he could install the third SCV.
I agree it would be nice to have a small Kubota like tractor for utility work, and a John Deere like tractor for heavier work, but since I hate worn out equipiment, that would cost a fortune. Also if you buy implements for a tracter much bigger than a 5310, they will need to be CAT 2 to take advantage of the horsepower, and probally too heavy for the smaller tractor. I looked at buying a small kubota but the lift capacity of the rear hitch is less than my 1050, and the weight and wheelbase are equal or less for the same horsepower. I know it wouldn't handle my disk (1150 lbs) and have doubts about my 5' rotary cutter (1000 lbs).
Thanks for the advice on the telescoping links.
Pat
/ Buying a 5310 #6
Just bought a 5410 after several weeks of shopping. Looked at the JD line from the 4600 up through the 5410. I thought the 5210 might be a little underpowered long term, and worried about turbo reliability, so I decided to go for the 4.5 liter engine without turbo, hence the 5410. It seems to have plenty of power. I got the 4wd 5410 with Power Reverser transmission, dual (joystick) SCV's but only the rear mount coupler location, telescoping draft links, and 800 lbs. of front weights for $27,700. The tractor was a fair demo unit and had 53 hrs. on it. Also got a slightly used 709 cutter for $2,900. I haven't taken the cutter off yet, but the telescoping links seemed like a good idea based on my prior experience. The 709 is so heavy there is no hope of moving it by hand to get it connected.
/ Buying a 5310 #7
Thank you for this post. Now I think I know what the telescoping links are for...attaching implements. And now that I think about it, I can see how it would benefit. I have some on my 5200 and did not know what to do with them. One came loose one day while brush hogging.
Fortunately, no damage resulted. I must have moved the knob to release it while standing on the draft links to add fuel.
Unverferth Perfecta 12 (A64126)
Unverferth...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
40' Shipping Container (A66285)
40' Shipping...
CASE TV450B Compact Track Loader (A65053)
CASE TV450B...
Great Plains Ultra Till 3030 (A63688)
Great Plains Ultra...
2014 KENWORTH T370 ROAD TRACTOR (A65054)
2014 KENWORTH T370...
