Buy a JD4010 vs. JD4110
   / Buy a JD4010 vs. JD4110 #1
mthiel
JD 4110
I have driven several JD model compacts and like the 4010 and 4110 for size and price.
I have priced the following configurations from a local dealer. The configuration is as follows:
4010 - $11,645 (18.5 HP, HST)
60" belly mower
48" LX4 rotary cutter with slip clutch
Hydraulics for future implements (FEL, blade, etc.)
4110 - $13,395 (21 HP, HST, and rebates)
60" belly mower
I plan to mow 2 acres and bush hog 3 acres with slopes.
Should I buy the 4010 or 4110? I don't know if I really need the extra HP in the 4410. Driving them at the dealer doesn't help me know.
Has anyone bought a 4010 and wished they had spent the extra for the 4110?
   / Buy a JD4010 vs. JD4110 #2
If you have to cut thick deep grass with a 60" MM the 4110 would be a better choice. A 54" MM would be a safer bet on a 4010 under the same conditions. John
   / Buy a JD4010 vs. JD4110 #3
My understanding is that the 4010 is more geared towards the kubota BX series. I recently purchased the 4110 , if you look at the specs for both the 4010 and 4110 you will see a big difference in hydro fluid flow , which can have an effect of attachment performance. To me the extra $ is worth it for the increased HP. Get all the machine you can afford now. My 4110 has the 410 FEL and filled R4's.
Go with the 4110 , you'll be glad you did :)
Mark
Thanks for the advice. I ordered the 4110 yesterday.
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2025 JMR 66in Single Cylinder Grapple Rake Skid Steer Attachment (A50322)
2025 JMR 66in...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2009 Dodge Ram Utility Pickup Truck, VIN # 3D6WC78L09G558300 (A51572)
2009 Dodge Ram...
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
