butter fingers
   / butter fingers #1
lahamm36
Love to repair things. Can't stand something to be broken. Working on a weedeater ZAMA carb.
I have taken it apart and found nothing bad,but it will only work with choke half on.????
   / butter fingers #2
Can't help with the weedeater part, but welcome! With a name like butter fingers could be you have plenty of repair to do!
:laughing:
Enjoy the forum.
   / butter fingers #3
Look VERY carefully at the inlet fuel lines. Some of these have a tendancy to get soft over time and will swell (shrink) shut restricting the fuel flow. Look inside the tank also. They are submersed in gas and this is frequently where they get mushy or break off.
P.S. I hate working on those little carbs. A spec of dirt and they don't work.
Roy
   / butter fingers
Roy,Thanks for quick reply.I have checked these parts. When you press primer it seems to draw air from inside of carb. Diaphragms are ok. Can any one help? Thanks.
   / butter fingers #5
just a dab of seafoam can work wonders sometimes, has for me more than once. Last fall when I started my backpack leaf blower after a year, it didn't want to open up without choke. I finally poured a dab of seafoam in with it running, it instantly killed it. I went and ate dinner, then came back and tried it, started right up and ran fine all fall!
   / butter fingers #6
Are you using brand new gas? Carbs all tuned up working properly?
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2019 Freightliner M2 106 18ft Landscape Dump Truck (A50323)
2019 Freightliner...
(2) Military Front & Rear Differential (A50121)
(2) Military Front...
