Tiller Busted Shear Pins on Kubota Tiller
   / Busted Shear Pins on Kubota Tiller #1
tcarter1
Rock Hill, SC
06 L2800 HST, R Long 4n1
Any idea why I keep busting shear pins on a Kubota tiller? It's a 60" behind a L2800. If I hit anything bigger/harder than soft dirt, away she goes.
   / Busted Shear Pins on Kubota Tiller #2
I don't have a tiller...YET..so my guess is you should have a slip clutch on your PTO shaft. Most tillers seem to come with this style and I figure there is a good reason for it.
this tiller doesn't have a slip clutch. But, it should be able to actually till the ground. I'm missing something. I had a 40" Bush-Hog for years that never acted up, and it saw some rough treatment.
   / Busted Shear Pins on Kubota Tiller #4
Yes most if not all brush hogs just have a sheer pin...mine does. The slip clutch is just something I see on all the new tillers I see and the one I will buy someday.
   / Busted Shear Pins on Kubota Tiller #5
you are tilling either too deep, too fast, or in too hard a soil. Slow down, and make shallower passes followed by deeper passes. Hitting rocks can snap the pins also. Mike
   / Busted Shear Pins on Kubota Tiller #6
Sounds like you need a harder shear pin but before going that route I would check with your dealer to determine the proper hardness.
   / Busted Shear Pins on Kubota Tiller #7
I have broken one shear pin (found a buried "T' post) on my tiller and its time to change the tines. I would say something is wrong with your tiller/shaft or operation. I wonder if the gearbox or drive is ok. It should be easy to turn by hand (engine off/pto disengaged). If it isn't you need to figure out why. If it does I guess slow down and/or till shallower is the solution. Your bigger tractor can indeed cause some damage but I've abused mine some without a problem.
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A55973)
2019 Chevrolet...
2022 John Deere 1025R (A53317)
2022 John Deere...
2019 FORD F-350 SUPER DUTY SERVICE TRUCK (A58214)
2019 FORD F-350...
2007 Ford E-350 Passenger Van (A55973)
2007 Ford E-350...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
