Tiller Busted Shear Pins on Kubota Tiller
   / Busted Shear Pins on Kubota Tiller #1
tcarter1
Bronze Member
Rock Hill, SC
06 L2800 HST, R Long 4n1
Any idea why I keep busting shear pins on a Kubota tiller? It's a 60" behind a L2800. If I hit anything bigger/harder than soft dirt, away she goes.
   / Busted Shear Pins on Kubota Tiller #2
I don't have a tiller...YET..so my guess is you should have a slip clutch on your PTO shaft. Most tillers seem to come with this style and I figure there is a good reason for it.
this tiller doesn't have a slip clutch. But, it should be able to actually till the ground. I'm missing something. I had a 40" Bush-Hog for years that never acted up, and it saw some rough treatment.
   / Busted Shear Pins on Kubota Tiller #4
Yes most if not all brush hogs just have a sheer pin...mine does. The slip clutch is just something I see on all the new tillers I see and the one I will buy someday.
   / Busted Shear Pins on Kubota Tiller #5
you are tilling either too deep, too fast, or in too hard a soil. Slow down, and make shallower passes followed by deeper passes. Hitting rocks can snap the pins also. Mike
   / Busted Shear Pins on Kubota Tiller #6
Sounds like you need a harder shear pin but before going that route I would check with your dealer to determine the proper hardness.
   / Busted Shear Pins on Kubota Tiller #7
I have broken one shear pin (found a buried "T' post) on my tiller and its time to change the tines. I would say something is wrong with your tiller/shaft or operation. I wonder if the gearbox or drive is ok. It should be easy to turn by hand (engine off/pto disengaged). If it isn't you need to figure out why. If it does I guess slow down and/or till shallower is the solution. Your bigger tractor can indeed cause some damage but I've abused mine some without a problem.
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
Tillit 3 pt Tiller (A50515)
Tillit 3 pt Tiller...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
