Rear Finish Mower Busted PTO shaft on finish mower
   / Busted PTO shaft on finish mower
Would it slide off just like the other end goes on the tractor? I haven't looked that closely at that end of the shaft
   / Busted PTO shaft on finish mower #12
Usually I use a vise to change them out.
The drive shaft should just slide apart. They are two piece.
   / Busted PTO shaft on finish mower #13
Half will stay with the tractor.
   / Busted PTO shaft on finish mower #14
A good vise is the platform I use too.
   / Busted PTO shaft on finish mower #15
No special tools are required. A hammer and a large screwdriver are used to remove a retaining ring either on the inside or outside of each cup of the cross bearing. Once removed, use a smaller diameter socket in a vise to press the cup out of the yoke. Repeat for the other 3 cups and if the yokes are not damaged, take the short yoke and a cup to the farm store for a match. If your vise jaws will open far enough, you can press the 2 cups in at the same time tight against the cross bearing. Reinstall the retaining rings and your done. Hardest part is not loosing the needle bearings out of the cups, the factory installed grease should hold them in place.
   / Busted PTO shaft on finish mower #17
I would suggest inspecting the U-joint on the other end of the PTO shaft by the mower. If one end is bad the other may be also.
There should be no looseness or slop in the joint.
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
204386 (A57192)
204386 (A57192)
2019 Cummins L9N 8.9L 6-cylinder Turbo Diesel Engine (A55851)
2019 Cummins L9N...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2013 TAKEUCHI TL10 SKID STEER (A52707)
2013 TAKEUCHI TL10...
