Loader busted hoses - xr4040h loaders
   / busted hoses - xr4040h loaders #1
hitecredneck1
athens,al
kubota svl75-2
After about two hours moving dirt, had two loader hoses damaged. rubbed thru both the protective cover and the hoses on the loader nut. Would be an easy fix but can't untighten the hoses even with two wrenches. any suggestions? Do I need to remove the loader to fix? Owned a kubota for 12 years and had no major issues, the LS has been a PIA.
   / busted hoses - xr4040h loaders #2
Sounds like someone needs to plan the hose routing a little better.
How old is the tractor, and is it usually parked outside in the weather?
If your hoses are JIC 37s, then I suspect that the threads have rust in them. The
original installer did not use any lube (no one does) and water got in there. I have
had trouble removing some old hoses in the past.
You might try a careful application of heat to the fitting, using a propane torch.
When reinstalling JICs, I like to put a little grease or oil on the threads.
tractor is new. spent more time at dealer than my farm.
got it off , took two men and a breaker bar. very tightly installed at factory
   / busted hoses - xr4040h loaders #5
Let the dealer do it that's something he should have checked out before letting out in the real world.
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A57453)
2016 Volvo VNL...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A56857)
2025 Kivel Fork...
