Bushy's 110
   / Bushy's 110 #11
Re: Bushy\'s 110
Joe,
Glad to hear all is well with your beast.I've got about 80hrs on mine now and she's runnin' like a top.As far as problems go,nothing major,a couple little things,like a bad hose fitting for the aux. hydraulics on the loader,which the dealer promptly took care of,and there was excessive(to me anyway) play on the main mount of the loader towers between the pins and the arms,and also on the hoe main pin,the dealer sent me various size shims that I installed and it tightened everything up nicely.One thing I did do for my own comfort though,was I removed the loader lever lock handel and put a blank plate over the opening after I removed it to keep dust out of loader lever linkage,I did this because my knee kept hitting it and causing it to lock the loader handel and also because I can't remember the last time I wanted to lock the loader handel for any reason on any machine.As far as taking the hoe off you should go for it,it is one of the simplest hoe removeals ever and it is all done from the seat,real slick!Also I got some information on cabs,Laurin cabs is making a hard cab that will be available in October,but it's gonna be real pricey $6000 plus another $2000 for AC,bit there is another company that is currently offering a soft cab for around $450 or so,not the prettiest thing but it looks like it would get the job done and it doesn't cost $6000,my salesman is getting me more info on the soft cab.Glad to hear all is well,happy diggin'!
   / Bushy's 110
Re: Bushy\'s 110
Deniscisar
Have you seen this picture? Open the attachment to the left. Bushy
   / Bushy's 110
Re: Bushy\'s 110
Have you seen this picture yet. Bushy
   / Bushy's 110
Re: Bushy\'s 110
How about this one....... By the way I've got about 90 hours on the 110 how. Lately, I 've been digging post holes for fencing. It works well. I would consider that little digging. The only trouble I've had lately is the plastic latch on the glove box came a part I fix that myself, though the wind opened the box and my log got wet. I was not too happy about that.
I recieved a request to do a product survey from JD. Alot of the questions have to do with dealer service. Some time ago the dealer asked me not to throw them under the wagon when this survey came.
I don't think I'm comfortable doing a survey, though I will write the factory repersenative with some, more to the point concerns. I think I'll start with, that I feel I paid too much for the machine, since seeing that others were receiving better pricing, with more on the machine. My reference here is that I've called other dealers for pricing as well as read post here on tractorbynet.com.
One of the other concerns I have is the excessive play in the swing function of the hoe. That is the most bothersome characteristic in any hoe. Bushy
   / Bushy's 110 #15
Re: Bushy\'s 110
Well the dealer found a snowblower that would work on the 110. It's an Erkine 72" with a 12' shute. They had one at the shop ordered for a housing authority to be mounted on a skid steer. Looks like a well design piece of equipment. The price is $4,700. installed. Installed meaning there's an electrical switch for the tractor. It has the quick attach plates for mounting. It's about $1,000. more than I expected. Again it's one of those times where I have to think about it. Let it snow !
   / Bushy's 110
Re: Bushy\'s 110
Just another note regarding the backhoe...........
Yesterday I was digging with the hoe on the 110. I had the bucket in the bottom of a four foot post hole cleaning it out.
While curialing the bucket in away that the front teeth are coming in contact with solid material. In this digging situation the boom lock was move back and forth depending on which way the bucket was being rolled. It was actually making a lite snapping sound.
As you know the boom lock is on the other end and sits on top of the sub frame and the sub frame is connected to the swing frame by pins. I do not understand how this hook and latch is moving. Unless the pins are moving. That would not be good.
This morning, I'll take a mental note of the possiable route of movement. As well, I will double check the part that are involved. Bushy
   / Bushy's 110 #17
Re: Bushy\'s 110
I have a 110TLB on loan from my JD dealer.
I do not notice much difference between the loader lifting power of the 110 versus the 4700's 460 loader.
The 110 backhoe is excellent.
The hydraulics noise is louder than the 4700. Have you noticed a high noise level on your 110?
Also the plastic fuel tank leaks.
Tony
   / Bushy's 110
Re: Bushy\'s 110
Turbotec Tony...........
Yes there is alot of hydralic noise. And it seems to be high pitched.
I recently used a loader on a 5000 series JD and I thought the 110 was much better. The 110 was quicker and the ground speed in relationship to the speed of the loader was far better due to the infinite variability of the hydrostatic transmission which the 5000 did not have. I find the 110's loader to be quit snappy. Of course this is not the same comparison as you are making nor do I know the model # of the loader on the 5000. Though it was a 1999 year model.
Before I purchased the 110 I tried a 1987 JD 1050 model, thinking I would buy a used machine and put a hoe on it. The loader on that was really slow though the tractor would climb right over the pile of dirt.
The tractors that I compare mostly are the two I traded, the one was a Ford 4500 and it's loader was strong both in lifting and curaling. It was quick as well. It was 1969 technology. That was a 54 hp tractor with almost a yard bucket. The other was a 1959 Ford 600 series TLB. It had a narrow bucket with add on snow buckets [you know you bolt them on to the existing bucket].
As you know the 110 is leps and bounds ahead of that old girl but when I had her a working I thought that I really had something. The rollback and lift was quicker than that 1050.
I've been reporting what goes on with my 110 since I got it. I would say that I am happy with it. And I trust that the things that are wrong with it, wheather it is workmanship or design will be made rigth by John Deere. Bushy
   / Bushy's 110 #19
Re: Bushy\'s 110
Bushy,
The dealer picked up the 110TLB today. I leaned that this unit belongs to JD. It is a pre-production model, (s/n 003). Therefore, it does not have the improvements that the production units have.
This unit will be returned to JD for complete disassembly and evaluation of the wear and tear from in service use.
Tony,
   / Bushy's 110 #20
Re: Bushy\'s 110
Bushy,Joe,and any other 110 owner,
Just thought I'd let you guys know that my dealer contacted me and said that someone from Deere may be coming out to see me in the next couple of weeks to see how the 110 is holding up,they were looking for a machine with about 150 hours on it and I have about 142 on it now.If you guys have any questions that you would like me to ask just let me know.I'm supposed to get a call from the Deere rep this week to confirm a time and day so as soon as I hear from him I'll let you guys know.Hope all is well with your diggers,mine is runnin' great,just hope the rain stops so I can get some work done this week.
2 Warehouse Forks (A55787)
2 Warehouse Forks...
1993 Generac Olympian 93A 100kVA Towable Diesel Generator (A56857)
1993 Generac...
23018 (A55758)
23018 (A55758)
2016 Husqvarna YTA18542 42in Riding Mower (A56859)
2016 Husqvarna...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2019 INTERNATIONAL...
2000 Nabors 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 40 Ton...
