bushog sharpening?
   / bushog sharpening?
Thanks all
Guess i am better leaving the edge alone. I cut more brush than grass depending on how often i cut. i usually only hit it once a year and don't want sharp stubs
   / bushog sharpening? #12
I broke the weld that holds the stump jumper on. It was only welded 1/4 the way around. Since I had the blades off, I noticed some larger dents and dings on the cutting edge. I took the blades off, mounted them up on the mill, and milled the edge. I left maybe a 1/8in blunt rounded cutting edge, but a good taper. Cuts weeds and brush well.
A rotary cutter is not a lawn mower. If you are looking for a tractor pulled mower that will leave the grass like a lawn, get a finish mower. But even those wont do as good of a job as your lawn mower. Might google search "Golf Course Mower"
I agree with what you said except the quality of the cut. Mine cuts like a mower. It is a mower, a 20 foot mower. Can't tell where the Ztrack stops and the FM starts.
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
Cushman Electric Cart (A55853)
Cushman Electric...
UNUSED FUTURE D5T 35" HYD TILT EXCAVATOR BUCKET (A57193)
UNUSED FUTURE D5T...
