bushog question
   / bushog question #1
anthonyk
houston texas
Century 3647
I've got an SQ600 Bushhog, that I pull behind a 47 hp tractor.
Is the front of the bushhog or the rear, near the support wheel supposed to be higher?
I think the owners manual seems to indicate the the front be lower, but I'm not sure (or is the darn thing supposed to be level, in which case I'll have to adjust the positioning of the wheel height)
any advice?
thanks,
anthony
   / bushog question #2
any advice?
thanks,
anthony
Commonly accepted practice to have the REAR set about 1" to 2" higher than front so that your blades don't end up having to cut everything two times.
   / bushog question
thanks, that's about what I've got now.
The height I cut at drops the 3 point hitch side a few inches lower than the rear wheel.
What you said about cutting twice seems to make sense too.
thanks,
anthony
Case Ih 2388 Combine (A50514)
Case Ih 2388...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
HONDA EB 5000X GENERATOR (A50854)
HONDA EB 5000X...
1240 (A50490)
1240 (A50490)
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
1981 LINK BELT HSP 8028 (A50854)
1981 LINK BELT HSP...
