Bushings for quick hitch
   / Bushings for quick hitch #1
Stomper
Saskatchewan, Canada
2017 Kubota L2501
I picked up an Agri Ease quick hitch from a local farm supply store. I assume it's a chinese made unit. It is a catagory one but he quick hitch part is not. I assume from the measurements that its a catagory 3, bottom hooks can fit a 1.5" shaft and the top a 1.25". I thought it was a cat 2 so I have already ordered the cat 1 to 2 bushings. The cat 2 bushings have a 1.125" OD. Will that be too much slop in the lower hooks or will it be fine.
   / Bushings for quick hitch #2
Should be ok. I have the harbor freight qh. Same issue. I did not measure but the 1 to 2 bushing took out most of the slop and it seems ok from there. Make sure to get 2 for every implement you have.
   / Bushings for quick hitch #3
All of the QHs are this way. As you figured out you need bushings to go to cat 3 lift pins. Almost any ag store like TSC will sell these that do it in one step or two bushings to do it in two steps.
CountyLine Quick Hitch Bushing Kit, Cat 1 at Tractor Supply Co.
CountyLine Lift Arm Bushing, Cat 2-3 at Tractor Supply Co.
CountyLine Category 2 to 1 Lift Arm Bushing at Tractor Supply Co.
If the attachment has an open-ended lift pins then the first lint is the better long term solution. If the attachment has captive lift pins then you need to nestle the bushing.
   / Bushings for quick hitch #4
What it should be ... And what it actually is, is two different animals...
Dale
   / Bushings for quick hitch #5
As others said the QH standard specifies CAT3 size pins for all sizes of QH. Northern Tool has the bushings online, lots of farm stores have them around as well. I have them on most of my impliments & a stash on a shelf. There are a few impliments I havent gotten bushings on for some reason & they actually work fine. If I recall, putting bushings on the lower pins on my tiller would cause insufficient clearance for the lift hooks between the pins & frame (poor engineering by King Kutter). I could welds things in a new spot, but it works fine without bushings. I'll fix it right so bushings fit if/when the pins break.
2020 CAT 239D3 Skid Steer (A44391)
2020 CAT 239D3...
2017 Chrysler Pacifica Minivan (A42744)
2017 Chrysler...
2016 Ford Explorer SUV (A42744)
2016 Ford Explorer...
2013 ALLMAND LIGHT TOWER (A45046)
2013 ALLMAND LIGHT...
2008 TRAIL MASTER, INC. GOOSENECK TRAILER (A45046)
2008 TRAIL MASTER...
2023 Ford Ranger Crew Cab Pickup Truck (A44572)
2023 Ford Ranger...
