bushings Cat 2 to Cat1
   / bushings Cat 2 to Cat1 #11
How wide is the space for the bushing? You can buy different width bushings.
   / bushings Cat 2 to Cat1 #12
As was mentioned, stack washers or cut down a bushing. My preference would be to stack washers or make a bigger diameter bushing so the side to side movement is minimized.
I had s similar problem with my snowblower. Blower was setup diameter wise for Cat1 and Cat2 but the blower Cat2 was too wide for the 3 point arms so I made new pins that were Cat2 all the way. Then made a bushing to control side to side movement.
I had hoped to post pictures but i dont see how on my phone.
I'm on a computer now so I can post the pictures of the pins I made. Maybe it will give you some ideas of what to do.
   / bushings Cat 2 to Cat1 #13
My solution to misfit problems were to get "quick hitch" and a one time, grind, cut , drill, weld on each implement to fit QH and move on.... Got better things to do with my time to constantly fight problem items....
Dale
2012 LINDE H80D FORKLIFT (A50854)
2012 LINDE H80D...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2016 Ford F-150 Crew Cab Pickup Truck (A49461)
2016 Ford F-150...
