Bushing 3008 friction disc
   / Bushing 3008 friction disc #1
RDP
N/A
N/A
I have a later model bushhog 3008 8 foot 3 point rotary cutter that is giving problems The rubber disc between the gear boxes seem to start coming apart. I am on the third set in 2 years. I run the pto at 540 rpm. The new discs have less than 5 hours of use. I replaced the bolts,nuts and special washers,torqued at 50 ft. Lbs. Anyone have an idea for a solution?
I thought so. If are off a little,is this the cause?
   / Bushing 3008 friction disc #4
IDK. Honestly I have not heard of anyone having your problem. And I have been around a few 3008 cutters. If the timing was off and cut crop was slugging where the blades run close I wonder if that could be hard on the discs.
The cuts are clean. I’m cutting mostly weeds like Johnson grass and iron weeds.
   / Bushing 3008 friction disc #6
Are you using genuine Bush Hog discs or aftermarket? I am not sure what difference that makes, I have sold a bunch of the aftermarket discs and never had a complaint.
I am quite puzzled by your problem. Are the shafts misaligned?
Aftermarket from A&I. I will replace discs and the blades. Maybe it will help. If not, I will take it to a dealer for help. Thanks for the help.
(INOP) 2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
(INOP) 2015 MACK...
2012 Ford Explorer (A50120)
2012 Ford Explorer...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2015 John Deere 310SL (A47384)
2015 John Deere...
2014 JOHN DEERE 17D EXCAVATOR (A51242)
2014 JOHN DEERE...
JOHN DEERE 6135RW401 MOTOR (A51243)
JOHN DEERE...
