Rotary Cutter Bushhog Top Link Question
   / Bushhog Top Link Question
What brand cutter is that? It looks an awful lot like mine, Titan Implements.
It is a Branson, which I think is the same as Titan (the manual says Titan).
Thanks, everyone! Sorry, work pulled me away. It does have lock nuts on all the bolts already, so should be good there. I will keep an eye on that though, am about to go loosen it up & run it today. If I need to, I can drill a hole for a pin (thanks for that suggestion, good one).
Much appreciated!!
Just to update -- I loosened that bracket enough to pivot without being loose enough to rattle & it worked great. Thanks again for the help, it is so nice to mow the pastures without scraping grooves into them. I should have figured this out faster, but the first year I had it, I still thought the seller knew what he was doing. Lesson learned!
   / Bushhog Top Link Question #13
:thumbsup:..Happy mowing
   / Bushhog Top Link Question #14
Glad you got it working but not sure what is up. You should have a bushing that will not allow tou to restrict the movement of the flex hitch. You may be OK but a well placed washer may fix everything.
   / Bushhog Top Link Question #15
That sounds like you have it adjusted as it should have been done by your dealer. Here's the instructions for that part of assembly: "Tighten the bolt sufficiently to eliminate side play,
but still allow the break link to function." :thumbsup:
   / Bushhog Top Link Question #16
Agree that if you don't assemble an item yourself, like one could experience in a shipment of mower decks, you are at the mercy of the local dealer's installer's experience and knowledge. Case in point, I bought a new lawn mower this winter. Found that the dealer was having numerous tires replaced. Never have seen that type of a problem on such equipment.....I checked mine and the tires were rated for 10 psi max and were sitting just under 30#.
The U shaped bracket is another example as you found out. It can't function if tight and worst case you will bend your 3rd member or worse. I had a neighbor, new to the farm arena, do just that on his new tractor-mower. He was lucky that the 3rd member bent and didn't tear up something on the tractor or mower.......but they have good range but there is a limit as to how deep of a ditch you can cross without binding.
I have used mowers with a chain on the bottom end of the bar and have modified mowers without a chain to having a chain. I like the swinging U the best.
The way dealer interpreted that step (although I am pretty certain he read exactly 0% of any instructions): "Put your air wrench on every bolt you can find & crank those puppies down until the head edges dig in to the paint." :indifferent: This has been a good reminder for me that I need to stick tight to one of my core life philosophies: don't trust anyone!
Texasmark, that is what I was afraid was going to happen if something didn't get loosened -- I kept looking back there nervously, not liking that there was no give point to dissipate that force. I might not be an expert mechanic, but I'm good at physics (especially good at demonstrating them through failure, heh). The previous bushhog I used had the swinging u-joint at the top, which I really liked too. I may look in to adding that in once I stop having to give all my money to the vet (hahahha, like accident-addicted horse is ever going to give up his campaign).
ETA -- :eek: about the tires & glad none of them blew up in your face before you discovered it!
   / Bushhog Top Link Question #18
HAHA horses always cost money even the free ones are not free ...........:)
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56435)
2018 John Deere...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
