Rotary Cutter BushHog SQ720 blades not turning.
   / BushHog SQ720 blades not turning. #11
Forgive my ignorance, how do you check for the shearpin?
The PTO shaft from the tractor to the cutter is attached to the input shaft of the gear box. If the PTO shaft turns and the input shaft of the gear box isn't turning, then you've got a sheared shear pin.
   / BushHog SQ720 blades not turning. #12
Bingo!
OK, found the problem, The unit I have has a slip clutch and it was WAY TOO LOOSE, i could see air between the plates. i tightened everything up and she runs like a champ. Thanks for all the input and advice.
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
2018 Chevrolet Tahoe SUV (A55973)
2018 Chevrolet...
2022 CATERPILLAR 301.5 EXCAVATOR (A52709)
2022 CATERPILLAR...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2017 Ford (A55973)
2017 Ford (A55973)
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
