Mowing Bush Mower PTO spd??
/ Bush Mower PTO spd?? #1
DirtPoor
Western WA USA
JINMA 204
I just finished installing my new Brush Mower (brush hog) on my Jinma 204. (The brand is Chipper FWIW)
I have a two speed PTO (540 and 1000 rpm) and I'm wondering what the correct speed should be. (assuming a standard gear head ratio)
I've tried both and the tractor seems ok with the higher speed but not sure if the mower is designed for it.. (sure makes a lot of noise, even before contact with the enemy)
BTW. I do have an over-run clutch and definately can see the benefit.
Thanks for any advice or experiences.
Steve
/forums/images/graemlins/grin.gif
/ Bush Mower PTO spd?? #2
Nearly all common implements sold in USA use 540, it likely will not run long at 1000!
/ Bush Mower PTO spd?? #3
You should follow the manufacturer's recommended PTO speed. If you do not have that information, 540 is the safest. There is an inherent potential for damage and injury using a brush hog in general, using one at the wrong speed raises the risks.
/ Bush Mower PTO spd?? #4
Steve,
I have a 5' KK BH and it recommends 540, I have never run it any higher. Most impliments are 540 as well.
/ Bush Mower PTO spd?? #5
</font><font color="blue" class="small">( BTW. I do have an over-run clutch and definately can see the benefit. )</font>
Hopefully you haven't already cut down the PTO shaft to accomodate the over-running clutch. They're for tractors without a 2-stage clutch and/or live PTO. The JM204 has both.
//greg//
Opps!!/forums/images/graemlins/confused.gif
I already cut 2.5" off the shaft to make it fit..
Just going by what my dealer recommended.
I can't see any harm in keeping it in the drive train, Can you??
Steve
/ Bush Mower PTO spd?? #7
Probably not for a while, till normal wear makes it start flopping around. Other than that, they're just ugly dirt and grease accumulators.
Creates a little credibility problem for the dealer though, doesn't it.......
//greg//
