Mowing Bush Mower PTO spd??
   / Bush Mower PTO spd?? #1
DirtPoor
Western WA USA
JINMA 204
I just finished installing my new Brush Mower (brush hog) on my Jinma 204. (The brand is Chipper FWIW)
I have a two speed PTO (540 and 1000 rpm) and I'm wondering what the correct speed should be. (assuming a standard gear head ratio)
I've tried both and the tractor seems ok with the higher speed but not sure if the mower is designed for it.. (sure makes a lot of noise, even before contact with the enemy)
BTW. I do have an over-run clutch and definately can see the benefit.
Thanks for any advice or experiences.
Steve
/forums/images/graemlins/grin.gif
   / Bush Mower PTO spd?? #2
Nearly all common implements sold in USA use 540, it likely will not run long at 1000!
   / Bush Mower PTO spd?? #3
You should follow the manufacturer's recommended PTO speed. If you do not have that information, 540 is the safest. There is an inherent potential for damage and injury using a brush hog in general, using one at the wrong speed raises the risks.
   / Bush Mower PTO spd?? #4
Steve,
I have a 5' KK BH and it recommends 540, I have never run it any higher. Most impliments are 540 as well.
   / Bush Mower PTO spd?? #5
</font><font color="blue" class="small">( BTW. I do have an over-run clutch and definately can see the benefit. )</font>
Hopefully you haven't already cut down the PTO shaft to accomodate the over-running clutch. They're for tractors without a 2-stage clutch and/or live PTO. The JM204 has both.
//greg//
Opps!!/forums/images/graemlins/confused.gif
I already cut 2.5" off the shaft to make it fit..
Just going by what my dealer recommended.
I can't see any harm in keeping it in the drive train, Can you??
Steve
   / Bush Mower PTO spd?? #7
Probably not for a while, till normal wear makes it start flopping around. Other than that, they're just ugly dirt and grease accumulators.
Creates a little credibility problem for the dealer though, doesn't it.......
//greg//
2025 KMR 40in Single Cylinder Grapple Skid Steer Attachment (A51691)
2025 KMR 40in...
Sany SY35U Pro Mini Excavator (A52384)
Sany SY35U Pro...
2022 John Deere 8R 340 MFWD Tractor (A53342)
2022 John Deere 8R...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
