Bush hogging is best without front loaders on
   / Bush hogging is best without front loaders on #81
good points LD1. with an 8' mower on an MX, you surely must have a drag type mower. in that case, & with the mid size tractor, removing the fel given the acreage makes sense. in my own case, given the weight of the 8' 3ph mower, retaining the fel is a must for me given the hills, etc.
as mentioned, fel removal is according to one's own setup. 500 acres is a lot to mow with an MX!,
previously had one myself, solid tractor, best regards
   / Bush hogging is best without front loaders on #82
No its a mounted cutter. Woods ds96 to be exact @~1600 pounds.
I dont mow 500 acres all at once. Its a mowing business. Like I said it is mostly ~5 acre lots that were once fields....but split up and sold and new people want to build a house but cannot see the lay of the land to stake out a building site. But some of them are mowing pastures, or commercial sites, etc.
Doing ~20 acres a week during mowing season.....its not hard to hit 500/yr. Just some of my larger jobs are 20-30 acres and I can do them in a single day.
   / Bush hogging is best without front loaders on #83
real nice setup & site. one day i'll post pics of my own spring fed ponds & similar pastures.
presently prepping a duck food plot for millet, red clover & hairy vetch in the late summer.
cheers
   / Bush hogging is best without front loaders on #84
cheers
Those are actually three different sites and none of them mine.
As I said....I run a mowing business and do this for hire
   / Bush hogging is best without front loaders on #85
regardless, nice site
   / Bush hogging is best without front loaders on #86
I cant imagine not having my loaders on , if i am using a tractor their will always be a use for the loader, the only time i could take it off would be while finish mowing around the structures which only takes a few minutes .
I think a loader is the most cumbersome piece of equipment you can have on a tractor. It extends the length at least by 50% and in my case even more. They are so easy to take off I can't imagine why anyone would leave it on. Aside from rocks which I don't have.
   / Bush hogging is best without front loaders on #87
Workinonit, funny how different folks are…I don’t even notice my loader mounted on my tractor..lol I never take them off, maybe once for a repair.
A loader feels like “armor“ for the front end, the hood, the front axle, in case I run into something. When in “uncharted waters” that’s a lot of peace of mind.
When my loader is down and bucket curled back, it makes my tractor maybe 5-6’ longer. Of course 5-6’ IS more length, but 5-6’ on a rig that’s already 35-40’ long isnt that much more. If I raise the loader, it isn’t any higher at all!
However, the extra protection, the ability to push over brush/saplings and break off branches, carry off boulders in a bucket, or carry a chainsaw, brush cutter, smooth out ruts, extra traction for front axle and as a counterbalance for the mower, etc. far outweighs a little extra length.
One place I could see removing loader is when cutting grass fields that have been mowed many times and there’s little unpredictability. I sometimes use my 7495 in open fields where theres grass. I used my Fastrac with no loader on really large grass fields where I know there’s no need or use for a loader. So I guess you could say I do both, but mostly with a loader.
But like they say “you do you, I’ll do me” ????……at least I think that’s what they say????
hahahaha
   / Bush hogging is best without front loaders on #88
We are all different for sure. If I left my loader frame on the bucket would definately have to come off. It's so big I can't see the ground in front of me. But as I said, it's not an issue for me. 2 minutes and it is off.
   / Bush hogging is best without front loaders on #89
Raise it up high so you can see under it!
Sometimes I’ll mow a property where there’s some soft areas. Bucket on loader lowered to ground plus a little down pressure, throw tractor in reverse and flatten the ruts! Anytime I see a rock, I pop it with bucket and scoop it up in the bucket and dump in the woods.
Just giving you some ideas ;)
   / Bush hogging is best without front loaders on #90
fair enough. how easy are your hyd lines to detach as well?
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
CAT EXCAVATOR BUCKET (A55745)
CAT EXCAVATOR...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
