Bush hoggin: How many hours?
   / Bush hoggin: How many hours? #1
Cataclysm
Platinum Member
ok
LS4155HC
Check my math. 26.4 acres. 13.6 hours @ 2 mph. The 2 mph is due to a gopher infested field. I checked the mph today on GPS during a test run. Nothing in the field even comes close to bogging the tractor, its just the gopher mounds.
The tool of grass destruction is a LS4155HC (55hp) spooling an 8' twin spindle Howse shredder.
So 5,280' x 8' is 42,240 sq ft.
x 2 mph is 84,480 x sq ft per hour.
26.4 acres is about 1,150,000 sq ft.
And 1,150,000 sq ft divided by 84,480 sq ft per hour is about 13.6 hours of actual mowing time. Obviously it will take more actual time but this will get me in the ball park.
Do I have my numbers and units correct?
BTW you guys probably already know this but google maps has a cool feature that will give you sq ft. I'm using that to estimate run times on reclaiming some neglected pasture. (shreddin, sprayin, discin and gopher gettin!)
Thanks in advance!
   / Bush hoggin: How many hours? #2
Why 5,280' x 20'? Isn't your mower 8' ? If so, it'll take 13.6 hours.
Ha! exactly right! The 5.5 sounded way too quick.
   / Bush hoggin: How many hours? #5
It is unlikely you will get a full 8' swath each pass, more like 7' is a reasonable guess. My 5' cutter actually gets about 4' each pass, with some overlap of the previous swath.
   / Bush hoggin: How many hours? #6
I use the same type mowing calculator and find that it is pretty accurate if I use a 50% multiplier. The areas that I mow are not open and required some stops, starts, and maneuvering.
   / Bush hoggin: How many hours? #7
Theoretical capacity (acres/hour) is calculated as ground speed (mph) * implement width (ft.)/8.25. Effective capacity is calculated by adjusting the theoretical capacity by a field efficiency factor to allow for overlap, turning, etc. See https://www.extension.iastate.edu/agdm/crops/pdf/a3-24.pdf for a listing of estimated field efficiency factors.
If you are willing to assume 82.5% efficiency (which should be in the ballpark for a rotary cutter), the formula for effective capacity (acres/hour) reduces to speed(mph)*width (ft)/10.
OP's situation: 2 * 8/10 = 1.6 acres/hour with 82.5% efficiency. 26.4 acres/1.6 acres/hour = 16.5 hours.
Steve
   / Bush hoggin: How many hours? #8
I used to mow a pretty decently kept hay field of about 25-26 acres with a 9' haybine in around 14 hours.
   / Bush hoggin: How many hours? #9
I bush hog about 20 acres of hilly land with a lot of turning and non square fields each year in 12 1/2 hours with a 6' cutter.
   / Bush hoggin: How many hours? #10
I do about a similar amount every year but never kept track of hours;not open by any means,lots of trees,rock walls and backing up.I used to mow twice a year but have cut down to once in August.I would guess I spent about 30 hours doing mine.
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
2017 JOHN DEERE 323E SKID STEER (A52709)
2017 JOHN DEERE...
2019 Deere 35G (A53317)
2019 Deere 35G...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
