Bush Hog violently shaking
   / Bush Hog violently shaking #11
That’s not as easy. I’d pull the shielding off and hook PTO shaft back up, then slowly spin up the mower at low rpm and take a look at the stub. See if it wobbles.
When you say “PTO shaft not bent”, did you remove the plastic shielding? It could be bent under the shielding.
Did you happen to notice one of the blades folded forward, but not stuck in place like with the sharpened side towards the pan when you checked the blades..?? If you had to pull the blade so it's straight out like it should be, then spun, that could have been the problem, knuckled ahead, and it makes it hard for centrifugal force to straighten out to cut and makes it unbalanced.
Awesome thought! I will pull it back up in the morning and check that!
   / Bush Hog violently shaking #14
I have had blades cross and get stuck before. Spinning them while crossed and they shake violently, but usually come uncrossed and all the vibrations stop.
David from jax
Similar to the above comment, I managed to bind some small piece of wood between the blade and housing that caused one blade to stop rotating and throw it off balance. Was a pita to remove that piece of wood.
   / Bush Hog violently shaking #15
If you tried to climb out of a steep ditch and the prop shaft had no more room to go up, you could have tweaked something. One way to eliminate the tractor is to hook the BH up to another tractor. But I think its something in the BH, starting at the blades and up to the prop shaft.
To eliminate your tractor, hook something else up to it and see if it shakes that attachment.
   / Bush Hog violently shaking #16
I would try disconnecting the drive Link lift the mower , crawl underneath and spin the blades and look for some out of place first
My PTO shaft is a connected 2 piece one that slides inside the other, I pulled back the plastic shielding and slid it in & out of each other no problem. I’m going to try to hook up another 3 pt this morning AND look underneath again to see if all the blades are turned at the same angle
   / Bush Hog violently shaking #18
The plastic shielding may slide easily, but the steel prop shaft inside might be slightly tweaked.
What you might want to inspect is the input shaft to the mower.
Also inspect the prop shaft U-joints. When you put the mower on an extreme angle, it may have tweaked a U-joint.
Start with the simple/easy things like bent blades, or blades that are not swinging properly, then move to prop shaft, u joints, then look at the splined input shaft on the mower
   / Bush Hog violently shaking #19
I suspect that’s what the situation is.
   / Bush Hog violently shaking #20
I tweaked a blade once and it would mostly rotate, but had one spot it would stick. The blade was bent, just a little . I had to remove it to repair.... maybe should have replaced it, but I did get it straight enough to work freely.
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
