Bush Hog TC30
   / Bush Hog TC30 #11
I'm always amazed by my tractor- its power and size. I used it for the 8" we got a while back- mounted a straight 7' snowplow on the bucket- worked great. I have an arthritic hip and using the clutch is great exercise for it!
We have had some very unusually warm weather here in Eastern Kansas. That coupled with a fairly heavy and much needed rain 2 weeks ago have played spring thaw havoc with our roads. So I decided to do a little road maintenance. I have owned three previous small very much older gasoline tractors; two 1960 vintage Fords and one old 2 point McCormick/Farmall (cannot recall the model :( ). This little TC30 can pull a 6 foot blade through some **** soft clay muck better than any of them! I put it in low (Hydro-static) and put full tilt on the blade to pull gravel out of the low drainage sides of my 1/4 mile of maintained roadway and it pulled gravel and dug into that soft heavy clay and pulled without a wimper. I had to lift the blade slightly because if was pulling more than I wanted!! I actually ran through some standing water spots and it still just kept chugging along. I'm sold on Diesel 4WD power.:thumbsup: I will finish working the roads today when I get home at noon. It should be dry enough now to actually work it. Just wanted to share my happy seat time. Happy New Year and a big thanks to all who contribute so much on this website and of course thank you TBN and sponsors:D
   / Bush Hog TC30 #12
weird weather. I', still putting out feed and weed and bug granuales, and can mow with shorts on and a ballcap.. ;(
   / Bush Hog TC30 #13
I believe it will still be awhile before shorts will be called for here in Eastern Kansas.:cool: However, I heard the weather man on TV state that no snow is forecast through the end of January! Normally I have to buy a snow blower or something like that to have weather this nice :D Not complaining...just amazed :thumbsup:
2014 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2014 MAGNUM...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
TEST BID LOT (A50774)
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
