Rotary Cutter Bush Hog stump jumper question
   / Bush Hog stump jumper question #11
The way I understand it is that it's not to help the blades in any way, they will swing away and hopefully not crack. It's mainly to keep the output shaft from snagging the stump and stopping you dead in your tracks and breaking all kinds of components. I would assume the ones with just a flat metal disc for the blades to mount on isn't really considered a stump jumper, I would think it needs to be the "pan" type with the bevelled-up edge so it rides up and over the stump. It's not really made to continually hit stumps, just to hopefully save you from severe damage on those "rare" occasions one finds you not paying attention !!
I suspect the rotating of the blades and what ever they are mounted to has more to do with it riding up and over a stump than the very slight angle used on a dished stump jumper pan. It might help but suspect any help it is so little it can not be measured. Just my thoughts.
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
20357 (A55758)
20357 (A55758)
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
