Bush Hog SQ84 cutter
   / Bush Hog SQ84 cutter #1
TxSam
Dumas, TX
LS MT357C
Anyone have experience with this cutter? I can get a used one for about $500. Does that sound like a reasonable price?
From what I know it has two blades, each blade has its own gearbox and it has two rear wheels instead of just one, I believe it is also lighter and shorter overall than the SQ72. I'll be using it with a NH TC35. Any feedback is appreciated.
Sam - Tractorless in Big 'D'
   / Bush Hog SQ84 cutter #2
<font color=blue>...I believe it is also lighter and shorter overall than the SQ72. I'll be using it with a NH TC35. ..</font color=blue>
For $500., if it doesn't need anything... absolute bargain...
However it's bigger... not smaller than the 72"...
Also you may have approached or went past your limit for a TC35, unless you're strickly using it to mow grass and not brush... and it's a heavy implement... have front weights and loader to keep the "nose" down...
{it should only have one gearbox on the Squealer series}
   / Bush Hog SQ84 cutter #3
Great mower for that price. New they run close to 2000. I like them because they don't tend to scalp as much as full round decks and they don't stick to far back from the tractor. Depending on what you are mowing I think you are buying a handful and maybe more as far as your tractor is concerned.
   / Bush Hog SQ84 cutter #4
I agree that it sounds like a bargain. John, according to their web site the SQ84T is available with a choice of single or double spindle. And it's wider, but shorter, than the 6' model. I'm not sure about the dimensions of the older models.
   / Bush Hog SQ84 cutter #5
<font color=blue>...the SQ84T ...</font color=blue>
I assumed it was the standard 84... the T is very rare and between a finish mower and rough cut... and not as heavy, or as long... well someone hand me a towel please, to wipe this egg off my face... /w3tcompact/icons/smile.gif
But, it's still a bargain @ $500.! /w3tcompact/icons/wink.gif
Sorry about that, you slipped a post in on me./w3tcompact/icons/smile.gif
Egg... what egg... Just good constructive discussion in my eyes! No problem! /w3tcompact/icons/wink.gif
John - It is definately the two gearbox model, I may have the wrong model number though. It is also shorter than the 72" since it has two blades intead of just one. As I think about it though, I'm not sure if it is heavier or lighter than the 72". I may have been thinking more in terms that since it is shorter that the counter-weight effect wouldn't be as pronounced. I'll look into it a little further and keep you posted.
Sam - Tractorless in Big 'D'<P ID="edit"><FONT SIZE=-1>Edited by TxSam on 12/07/01 09:18 AM (server time).</FONT></P>
   / Bush Hog SQ84 cutter #7
Sam,
If anything... buy it to resell it {as long as everything works}... I'd venture to say, you could easily double your money if it's right... /w3tcompact/icons/shocked.gif
John - /w3tcompact/icons/shocked.gif is right! I just thought it would make a good rough cutter. I was originally thinking of getting a finish mower but the cost was prohibitive. If it gives a good 'in-between' type of cut I'll be ecstatic! It just needs cleaned up a little and maybe a little PM (preventative maintenance) and maybe sharpen the blades. Is sharpening these type of blades even possible?
   / Bush Hog SQ84 cutter #9
<font color=blue>Is sharpening these type of blades even possible?</font color=blue>
Yes, I sharpened the ones on the last Bush Hog SQ48 so many times, I finally replaced them with new blades. So far I've only sharpened the ones on the Howse I now have once. Getting the blades off some of the brush hogs isn't too bad, and getting them off others is all but impossible./w3tcompact/icons/wink.gif So a lot of folks sharpen them with an angle grinder without removing them. Of course you don't want them quite as sharp as the blades on a lawnmower; preferably leave a flat front edge of approximately 1/8". Of course if I were only mowing grass and weeds; no brush or woody material, then I'd sharpen them a little sharper.
Thanks Bird - Sounds good to me! /w3tcompact/icons/wink.gif
We'll see how it goes!
INDUSTRIAL UNISAW TABLE SAW (A51248)
INDUSTRIAL UNISAW...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
(APPROX 60) DIAMOND TREAD DBL AXLE FENDER BACKS (A51247)
(APPROX 60)...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
HEAVY DUTY TRACTOR BRUSH GUARD (A51247)
HEAVY DUTY TRACTOR...
