Bush Hog SQ600 gear oil capacity?
   / Bush Hog SQ600 gear oil capacity? #1
2dawoodz
I can not find an online manual for the SQ600. I replaced the gear oil with 2 quarts of 80w90. Is this sufficient?
   / Bush Hog SQ600 gear oil capacity? #2
Bushhog.com has a pretty good manuals section did you look there?
   / Bush Hog SQ600 gear oil capacity? #3
Bush Hog does not list the SQ600 manual on their website but EP80W-90 Gear Oil is what all the Bush Hog manuals call for the gear boxes in the rotary cutters. The SQ160 five foot mower manual calls for 2 Quarts of EP80W-90 Gear Oil so you should be OK. :2cents:
   / Bush Hog SQ600 gear oil capacity? #4
Two quarts sounds correct. Typically the correct gear oil level will cover 1/2 the input shaft. Most have side plugs that set the level to the correct amount. If you overfill no problem as long as your vent plug is working properly.
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2016 Ford Explorer SUV (A51694)
2016 Ford Explorer...
