Bush Hog SQ600 gear oil capacity?
   / Bush Hog SQ600 gear oil capacity? #1
2dawoodz
Bronze Member
I can not find an online manual for the SQ600. I replaced the gear oil with 2 quarts of 80w90. Is this sufficient?
   / Bush Hog SQ600 gear oil capacity? #2
Bushhog.com has a pretty good manuals section did you look there?
   / Bush Hog SQ600 gear oil capacity? #3
Bush Hog does not list the SQ600 manual on their website but EP80W-90 Gear Oil is what all the Bush Hog manuals call for the gear boxes in the rotary cutters. The SQ160 five foot mower manual calls for 2 Quarts of EP80W-90 Gear Oil so you should be OK. :2cents:
   / Bush Hog SQ600 gear oil capacity? #4
Two quarts sounds correct. Typically the correct gear oil level will cover 1/2 the input shaft. Most have side plugs that set the level to the correct amount. If you overfill no problem as long as your vent plug is working properly.
2025 K3325 UNUSED Double Garage Steel Barn (A53117)
2025 K3325 UNUSED...
40' shipping container (A52377)
40' shipping...
2020 CHEVROLET SILVERADO (A53843)
2020 CHEVROLET...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
