bush hog size
/ bush hog size #1
catsam
knoxville,tn
mahindra max 28 xl
Just purchased a Mahindra 28xl with shuffle trans. will a 5ft bush hog or 4ft work the best. I have 5 acres to mow.
/ bush hog size #2
5 ft is what I would use
/ bush hog size
I was told a 5ft hog is to large for a 28hp tractor.
/ bush hog size #6
In my opinion, if I bought a 4 ft hog, I would be wishing I had bought the 5 ft. I am pulling a 6 ft with 29 hp now. It is to heavy for the tractor but it cuts OK as long as I leave the tail wheel on the ground. If I pick it up the front of the tractor comes off the ground and there are two weights on front end. I have a 5 ft and it works perfect for me. I just wanted to see how well the 6 ft would work.
/ bush hog size #7
Using the 5hp per foot formula, I'd say it sounds about perfect. I'm running 54" (4.5ft) with 22HP.
Joe
Exactly right. The Mahindra Max 28xl has 23.5 hp at the pto. A 4' cutter would not cover the width of the tractor. I have a 2615 with about the same pto hp, and have no problem with my Bush Hog Squealer, SQ60, a medium duty 5' cutter. I wouldn't be satisfied with a 4' cutter.
/ bush hog size #8
I used a 5 foot bush hog on my initial cut of 3 foot tall brush on a Max 25 without a hitch. I only went through two shear bolts on 4 acres. And those were in depression areas that were really rough. So I think you'll be fine.
Travel Trailer (A66738)
Travel Trailer...
MANIFOLD (A68842)
MANIFOLD (A68842)
New Quick Attach Hay Spear (A65563)
New Quick Attach...
2020 Chevrolet Tahoe (A68183)
2020 Chevrolet...
MAC FLAMELESS HEATER (INOPERABLE) (A68842)
MAC FLAMELESS...
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A67714)
2007 PETERBILT 335...
