Bush Hog Size for BX1800 Kubota - noob question.
   / Bush Hog Size for BX1800 Kubota - noob question.
FWIW, with the input from everyone here and some that I found on the Howse implements site it looks like a 36" to 42" bush hog is the right size for the little BX. I'll brobably go with the 42".
Now, to find one that doesn't break me...
   / Bush Hog Size for BX1800 Kubota - noob question. #12
</font><font color="blue" class="small">( I can't imagine a 5 foot hog on a smaller tractor )</font>
Wow.. I always felt my 5' mower on my Ex-Nh 1920 was 'underkill'.. as in I needed a 6' mower. Never did bog the tractor down whether it was 3' thick grass.. or 7' weeds.
Guess terain might make a difference as well as tractor weight. That tractor sounds like it may have a lighter frame than mine did.
Soundguy
   / Bush Hog Size for BX1800 Kubota - noob question. #13
just began using a 5ft rotary cutter behind my DX40, I don't believe the tractor knows it is there, I have not used it in tall grass yet, mostly shumaks and berry bushes, but, am currently thinking about getting a 6ft, Any body's opinion on this?
Is it worth the Jump?
Will the Tractor then begin to bog down?
Would the Wife Kill me? /forums/images/graemlins/crazy.gif
Ken
   / Bush Hog Size for BX1800 Kubota - noob question. #14
The 5 hp per foot rule is a pretty good one for average use, so for a 40 hp at the pto you will do just fine with a 6 footer. My FIL runs a 6 foot on a NH TC 30 so he has a bit less than 30 pto hp obviously, but he does fine with it. He just has to slow down a bit in real tall or thick stuff, or take smaller bites.
The advantage ( sometimes ) of having to big a mower is that if you aren't cutting very thick grass or brush, you will be cutting more width on each pass.
I'm almost scared to admit I use a 5 foot woods rotary cutter and a 6 foot King Kutter finish mower on a Kubota L2350 which has 25 total hp, they work fine for my use as I never let the pastures get that tall before I cut them, and I don't have any brush left to mow at all. I am at the point where I mow the pastures with the finish mower and the rotary cutter gather dust and chicken droppings ( on the fresh coat of paint I put on it last year but that's a different story ).
   / Bush Hog Size for BX1800 Kubota - noob question. #15
Well, that was then, this is now. I've bought a JD2040 with FEL and box blade...and, I'm in the market for a 6' bushhog for the Deere. I may keep an eye out for a small mower for the BX but for now, it looks like I'll do it all with the green machine.
Thanks for all the guidance and advice!
   / Bush Hog Size for BX1800 Kubota - noob question. #16
I've used a 42" KK with my BX1800 for 3 years now and have been very happy with the performance. I mow some pretty uneven terain with a creek running through it. I did have to lower the pins on the KK because the lift arms are low on the BX but other than the slight modification it works well.
   / Bush Hog Size for BX1800 Kubota - noob question. #17
I have a bx 1800 and a 5' land pride brush hog, it handles it well in all situations and cuts up to 11/2 inch wood with out problem
   / Bush Hog Size for BX1800 Kubota - noob question. #18
I use a 4 foot bushhog on my 18.5 hp JD that's about the same weight as your BX. Works fine. I let my turnbuckles go a little slack and bent the 3ph bar the lower arms come off of. Be sure and keep the turnbuckles tight.
Ralph
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
Allis Chalmers Disk (A50515)
Allis Chalmers...
2 Row Cultivator (A52128)
2 Row Cultivator...
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2019 FREIGHTLINER...
2018 JLG SKYTRAK 6036 TELESCOPIC FORKLIFT (A51242)
2018 JLG SKYTRAK...
