Bush Hog repair question
   / Bush Hog repair question #61
I would buy a new one. Repair here would be $200+. Just not worth the risk. Be glad
You found it before it broke completely
   / Bush Hog repair question #62
I have an old 6’ Bush Hog that has a cracked blade bar at the edge of the shaft hole for the gear box. It doesn’t have a stump jumper, and I hit the bar on a stump the last time I mowed. Is this something that can be safely welded to repair, or is that too risky? I know balancing will be an issue, but being right at the center hole should help. Otherwise, the part is $440 on an old cutter, so would be a total loss and would replace the bush hog.
I wouldnt worry about throwing it out of balance, you would have to put considerable amount of weld to effect balance much
2500 Gallon Fertilizer Tank (A57149)
2500 Gallon...
UNUSED FUTURE NWS38 38" WOOD SPLITTER (A58376)
UNUSED FUTURE...
Eagleline 3Pt 6' Box Blade (A57148)
Eagleline 3Pt 6'...
2016 Ford Transit 250 Cargo Van (A56858)
2016 Ford Transit...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
