Rear Finish Mower Bush Hog Rear Discharge Finish Mower
   / Bush Hog Rear Discharge Finish Mower #1
Dale_Alan
I have a Bush Hog 72" rear discharge finish mower with about 60 hours on it. The front solid tire caster wheel bearing is shot. It is a pipe sleeve with a pressed bushing one each side of the wheel hub and bolted with a long 1/2" bolt to the caster yoke. The strange thing is only the front two wheels are bad and only one side of the wheel bushing is badly worn. It almost looks to me as if the wrong bushings where installed one one side to start with. How could only one side of the caster be worn? I will be at the dealers in the am to see what they think. Any body got any ideas?
Dale
   / Bush Hog Rear Discharge Finish Mower #2
Did you grease it regularly?
   / Bush Hog Rear Discharge Finish Mower #3
My finnishing mower belt keeps breaking and they are expensive ,Set tension at reguired 2.8 inches and it stills breaks
   / Bush Hog Rear Discharge Finish Mower #4
You have either a bearing failing or something is out of alignment. Belt should last years.
   / Bush Hog Rear Discharge Finish Mower #5
Agreed...
Check bearings, tension, and alignment...
I've replaced 1 belt in 20 years of using a RFM...
As far as the wheels and bearings, that is one item you need to grease every time...
I grease my wheel bearings and tension spring shafts on my Woods each time that I mow...
I grease the bearings in the deck and universals every 2 or 3 times...
I think that the owners manual specifies every 25 hours on the bearings in the deck...
I know that I over grease...
Never had a bearing failure in 20 years...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2017 JOHN DEERE 8270R LOT NUMBER 189 (A53084)
2017 JOHN DEERE...
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
