Rotary Cutter Bush Hog or Kodiak 8 ft twin Heavy Duty
   / Bush Hog or Kodiak 8 ft twin Heavy Duty
Soundguy said:
Running the front high makes the tractor work more.
As the other poster pointed out.. King Kutter and Kodiak are not the same, and there is a percieved quality difference between the two.
soundguy
Hi Soundguy
Which one do you thank is the better of the two?
thanks Bruce
   / Bush Hog or Kodiak 8 ft twin Heavy Duty #12
I think the KK is going to come in a neck higher..
soundguy
Hi Soundguy
Do you know what the Gear box ratio on the K K is
The Kodiak t box is 1.22 and the side boxes are 1.46.
We are still trying to get it to cut the way we want it to.
Thanks Bruce
   / Bush Hog or Kodiak 8 ft twin Heavy Duty #14
Check their website for the manual.. it should be liste din the back.
Soundguy
We got the rotter cutter working good.
We changed the gears from 1.22 to 1. 47 on the main gear box.
so thats is equal to 1.93 speed up on a 540 rpm pto.
We also found that the drag chains on the front where in a loop
Instead hanging seperatly.
Causing the grass and weeds to be pushed down
So the blades could not get to them easly.
We took the chains off.
Also leveled it up and drive slow.
The cut looks almost as good as some lawn mowers.
GM.
   / Bush Hog or Kodiak 8 ft twin Heavy Duty #16
sounds great..!
soundguy
GM.
Still working 2 years later
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A53421)
2024 AGT LRT23...
CATERPILLAR 420 LOADER BACKHOE (A52707)
CATERPILLAR 420...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2009 NISSAN Murano AWD SUV (A53424)
2009 NISSAN Murano...
17301 (A55853)
17301 (A55853)
Shell Antique Fuel Pump Art (A55853)
Shell Antique Fuel...
