bush hog on my L4400
/ bush hog on my L4400 #1
cmharcou
whats the largest I can use? 6 foot or 8 foot?
/ bush hog on my L4400 #3
6 foot works really well, but be careful with the weight. A medium duty 3 point 6 footer will run close to 1200 lbs and if you try to lift it you'll need alot of suitcase weights or the FEL to keep the front wheels on the ground. I believe the weight limit for a bush hog on an L4400 is around 880 lbs, same as my L4300.
Standard duty 6 footers are around 750 lbs. Should be no problem.
Bob
/ bush hog on my L4400 #4
I use a 10 ft. pull behind on my L4300. It works great. I cut grass and small brush only.
/ bush hog on my L4400 #5
I stay with the 6 foot. The 8 foot is too heavy.
/ bush hog on my L4400 #6
I would agree. Stick with the 6 foot standard or medium duty that stays within the 3pt hitch rating. I have a JD LX6 (considered a light duty mower but weighs as much as some mediums) and it works well and balances well with the FEL on.
With a pull type mower you are mainly limited by how much PTO horsepower you have since they don't put any weight on the 3pt. I've run a heavy duty single spindle 7 foot pull type behind my L4400 through thick waist high brush with no problem.
INOP/NON - RUNNING 1997 Procraft Fish/Ski Boat (A65579)
INOP/NON - RUNNING...
Hedge Posts (A65640)
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
New Quick Attach Hay Spear (A65579)
New Quick Attach...
50in 3 Point Hitch Tiller (A65579)
50in 3 Point Hitch...
2020 Ranger 1000 XP (A62679)
2020 Ranger 1000...
