Buying Advice Bush hog on a toolcat
   / Bush hog on a toolcat #1
birddog0304
Northeast TN
John Deere/Massey Ferguson/Bobcat
Thinking about putting a 6 ft bush hog on front of my A series Toolcat . Any thoughts, opinions or experiences?
   / Bush hog on a toolcat #2
60" would work a little better on there, but either will work. You have the hydraulic capacity to run it, what you will find is the little weak to handle that heavy of load that far out in front. Biggest problem would be if you raised and rolled it down to sharpen or replace blades, there isn't enough tilt/bucket roll force to bring it back up level. lower the boom and roll back at same time will get it back to level.
If you do not have the extra debris screen over the radiator, get one. Without it grass & weed clippings lodge in radiator quickly. With the debris screen will plug up but it is much easier to clean off than cleaning between radiator fins.
Went with the 6 ft. Just spent 2 hours cutting around ponds, gates and fences. SSDoxie, you were right in all aspects. Handled well, but won't set any land speed records. Perfect to finish up were you can't get in with the 15 ft batwing.
   / Bush hog on a toolcat #4
We need an update now that you have had it awhile. Is it the Bobcat brand Brushcat?
Does it operate with the boom in float?
Have you cut any trees over 2"?
Have you had any overheating problems?
Thanks.
2020 Sellick S80 (A53317)
2020 Sellick S80...
E-Z-Go Workhorse Utility Cart (A55851)
E-Z-Go Workhorse...
STAR EV 36V ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
STAR EV 36V...
UNUSED GRASSROOTS IMPLEMENT 6' BOX BLADE (A57192)
UNUSED GRASSROOTS...
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
UNUSED FUTURE 12" CAT 305 EXCAVATOR BUCKET (A57193)
UNUSED FUTURE 12"...
