Grading Bush Hog MBX 72 Box Blade
   / Bush Hog MBX 72 Box Blade #1
gumshu
Platinum Member
JD 2025R TLB, Kubota L4802 and Can Am Defender HD7
Guys,
Just bought a new Bush Hog Heavy Duty 72" box blade with floating rear tailgate. It weighs 640lbs and I bought it mostly for rear ballast. I know Bobcat calls for 880lbs ballast for max lift, but this will have to do for now.
   / Bush Hog MBX 72 Box Blade #2
Guys,
That's a lot of box blade for that tractor, but it should make a great ballast weight!
   / Bush Hog MBX 72 Box Blade #3
I have a ct230 with 72'' King Kutter box blade (500 lbs) works fine as rear ballest even with 68'' bucket full of dirt.
the 30 hores have no problem pulling it even when full clay w/teeth engaged
   / Bush Hog MBX 72 Box Blade #4
I think you misspelled horses or something else. All I know is there were 30 of them…sounds like the making of a great story.
   / Bush Hog MBX 72 Box Blade #5
I think you misspelled horses or something else. All I know is there were 30 of them?ounds like the making of a great story.
You just NEVER completely know on TBN
:confused3:
   / Bush Hog MBX 72 Box Blade #6
Anybody see when this thread was started ? :)
Boone
Well you should be able to give a good review!! CJ
It's been a good box blade. Heavier than most and provides good ballast for the most part. If I had loaded tires, that would take care of any ballast issues. I haven't loaded my tires to keep my loads as light as possible for long hauls. Overall, the box blade is well built with corner gussets and a floating rear tailgate. It's set up for either cat 1 or 2 use. At the time of purchase, I also liked the John Deere Frontier, but it cost more. I picked this one up for $1000.
   / Bush Hog MBX 72 Box Blade #10
I hate to say it but the only time I use my Gannon roller box blade for what it was intended for is the scarifers [sp] for ripping up Aften. I have a hitch welded on it and chainsaw mounts along with it giving me 1000lbs of ballast but that is about all it is used for. CJ
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
2012 HEIL CRUDE TRAILER (A55745)
2012 HEIL CRUDE...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2013 TAKEUCHI TL10 SKID STEER (A52707)
2013 TAKEUCHI TL10...
