Rotary Cutter Bush hog hp requirements
   / Bush hog hp requirements #11
Z-Michigan said:
Based on my experience to date I think this is a good rule of thumb. I have 8 PTO hp per foot (6 ft cutter and 47 PTO hp) and I find that this setup is massively overpowered.
i'm strongly considering this same setup with my next tractor purchase. i think i'm gonna buy a medium duty cutter. have you ran into any problems with your setup as it is?
   / Bush hog hp requirements #12
I have run into 0 problems since I got my LX6 corrected (the blade pan had been damaged somewhere in shipment, but with help from TBN I noted this before ever using it and got it fixed under warranty).
I think an MX6 or Woods equivalent would be a good match. Also, a 7' lift cutter or 8' pull type cutter should be fully within the 5105 capabilities if you want something larger. I have the horsepower to mow at 10mph in 6th gear. Unfortunately this bounces me out of my seat and doesn't do much in the way of effective work. YMMV.
   / Bush hog hp requirements #13
Obviously, you need to cut bigger stuff....
jb
Thanks for all the great advice. Now I will have some good background before I get to the dealer.
Dennis
   / Bush hog hp requirements #15
art said:
The type of transmission also changes the requirements a bit as a hydro gives more flexibility.
And needs more HP.
   / Bush hog hp requirements #16
It needs 5 PTO hp or more per foot. There are many variables. 5 HP doesn't do a good job with the type of mowing that I do even though I know that it would for many.
   / Bush hog hp requirements #17
The 5hp per ft rule of thumb is more or less a minimum requirement. Take in to consideration what conditions you're mowing in. Hills? Heavy grass/weeds? Brush? I mow with 40hp/6' 47hp/6', 60hp/7', and 95hp/15'.(all pto hp's) All 4 have seen conditions where they meet there match. In MOST conditions they cruise effortlessly. Over-kill is better than underpowered. You don't have to use every speck of power a tractor produces, but not enough power is hard to overcome.
HP relates to physical size of the tractor to a certain degree. An often overlooked aspect is how a tractor handles the weight of a certain mower. Heavy duty mowers are usually HEAVY....Comparable width requires bigger tractor (hence "more power") from light duty to heavy duty.
   / Bush hog hp requirements #18
dennis5150 said:
Is there a general rule for how much pto hp is needed for various sizes of bush hog type rotary mowers? I will be needing to cut tall (2-3ft) grass hay, lots of blackberry bushes , small diameter saplings. Am I going to need at least 25hp, or will 18 to 20 work? Any advice is appreciated.
I have a Kubota B7510HST (21 hp engine, 17 hp pto) and a 4-ft King Kutter hog for my 7-8 acres of weeds on my 10-acre parcel. It handles 3 ft weeds OK if I mow slow in low gear (about an hour per acre). Don't have blackberry bushes or saplings so I can't help you there.
   / Bush hog hp requirements #19
My experience, while far less than many here, is the "5HP/FT" rule of thumb is pretty meaningless out of context. I'm running a 72" behind my 3130HST, and it works just fine. At 24 PTO HP, that's only 4HP/FT.
That being said...I've got little more than rough field grass/weeds to mow. The brush I do have is pretty small - rarely more than 1.5". I also never mow when wet. In these conditions, even on hills, I can easily cut through 5' tall material at 5MPH.
Some may consider the above conditions optimal or rare...but for me, and possibly others, they are the norm.
   / Bush hog hp requirements #20
How many here have actually bogged down a rotary cutter? I've read tht 5 HP per foot "rule" for quite a while, but have read of few folks that had issues with their cutters.
First year I had my 5' cutter, it was operated behind a 16 PTO HP tractor. That's less the 4 PTO HP per foot. I had no problems...just use common sense when you operate the unit.
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
JCB 8029 CTS EXCAVATOR (A52709)
JCB 8029 CTS...
(7) Ten Hole 25 Inch Steel Rims (A57454)
(7) Ten Hole 25...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
John Deere 1025R (A53317)
John Deere 1025R...
Mini Excavator Quick Coupler (A57149)
Mini Excavator...
