Rotary Cutter Bush hog hp requirements
   / Bush hog hp requirements #1
dennis5150
Is there a general rule for how much pto hp is needed for various sizes of bush hog type rotary mowers? I will be needing to cut tall (2-3ft) grass hay, lots of blackberry bushes , small diameter saplings. Am I going to need at least 25hp, or will 18 to 20 work? Any advice is appreciated.
   / Bush hog hp requirements #2
The rule of thumb is 5 HP per foot of cutter. Thus a 5 foot bush hog requires 25 HP.
   / Bush hog hp requirements #3
Every rotary cutter should have a minimum PTO-HP spec.
   / Bush hog hp requirements #4
Sometimes the type of terrain requires a larger tractor to hold a mower then the horsepower per foot but that is a good rule in general.
The type of transmission also changes the requirements a bit as a hydro gives more flexibility.
   / Bush hog hp requirements #5
You can do it with 18-20 HP. I used a 60" cutter behind a 16 (PTO) HP tractor. But you'll be going slow, which is a good idea if you've never cut the field before.
As far as gear vs. hydro...either works so you mow with what you got.
   / Bush hog hp requirements #6
Dennis - whereas I agree with Deerlope's rule of thumb, it should be qualified that he's talking 5 PTO horsepower per foot of rotary cutter. Another general rule is to try to get a cutter that is at least as wide as your tire tracks.
//greg//
   / Bush hog hp requirements #7
Dennis:
Deerlope is correct about the rule of thumb of 5hp/ft. My practical experience indicates that you may be able to get by with a little less if you have a "light duty" mower like the Bush Hog Squealer that uses 3/8" thick blades rather than 1/2" (or even 5/8") thick blades like the medium and heavy duty Bush Hogs.
I have both a light duty Bush Hog Squealer 480 (4' with 3/8" thick blades) and a medium duty Bush Hog 285 (5' with 1/2" thick blades). I was surprised when mowing side by side in 3' grass/weeds (an overgrown pasture) that the light duty Squealer on an 18hp (pto) tractor could travel significantly faster than the medium duty 285 on an 29hp(pto) tractor, yet the Squealer had only 4.5hp/ft and the 285 had 5.8hp/ft. I could attribute the difference only to four things: 1. The light duty mower had 3/8" x 3" blades while the medium mower had 1/2 x 4" blades; 2. the light duty blades were "flat" with no wing to create an uplift while the medium duty blades had the wing at the back of the blade ends; 3. the light duty mower had a 40hp gearbox while the medium duty had a 70hp gearbox, which probably had slightly more friction losses; and 4. with a 6" overlap on the prior cut, the actual cutting widths were 3 1/2ft and 4 1/2 ft, which changes the hp/cut ratio to 5.14 and 6.44, respectively.
If there is a lesson in my experience it is that there are disadvantages (in addition to higher cost) in buying a heavier duty mower than is required. The light duty Squealer is rated for 1" brush, but I have used it on 2" softwoods for years and it seems to have suffered no damage. If your saplings are no larger than 2" softwood (pine, etc.) or 1 1/2" hardwood (oak, etc.), consider a "light duty" mower like the Bush Hog Squealer. You will save on the original cost, it will cut hay, grass, etc. faster than the heavier machine, and you can use a smaller tractor.
   / Bush hog hp requirements #8
dennis5150:
Welcome to TBN :D! Deerlope is stating the general "Rule of Thumb". I read somehere that light duty rotary cutters require 2 HP per foot and heavy duty RC's require 5 HP and that a HD unit could take on 2" diameter saplings (I am assuming soft woods.). I have no current problems going through 7A's of vegetation like yours including cutting up weeds 5' -6' and the occassional +1.5" softwood sapling with my 60" MD RC powered with 23+HP PTO. I also cut the same area with a lot more poplar sapling in the 2'' range with a 40" HD RC powered with 11HP PTO with my old tractor (It would stall out on occassion.). What you can cut also depends on whether or not your RC is light, medium, or heavy duty with the respective upgrades in metal, gear boxes, and weight with corrsponding upgrades in HP. Jay
   / Bush hog hp requirements #9
Based on my experience to date I think this is a good rule of thumb. I have 8 PTO hp per foot (6 ft cutter and 47 PTO hp) and I find that this setup is massively overpowered.
   / Bush hog hp requirements #10
Yea, maybe, but isn't it somewhat satisfying just knowing that you can back that thing over just about anything and grind the he** out of it? :)
Sometimes I just like to "see" if I can cut it up rather than digging it out. Ok, testosterone out of my system now.
dw
Fast 9613N 1300 Gallon Sprayer (A57148)
Fast 9613N 1300...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2019 KENWORTH T680...
2013 Chrysler Town and Country Van (A56859)
2013 Chrysler Town...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
CAST IRON POT (A58374)
