Rotary Cutter Bush Hog Help
   / Bush Hog Help #11
My kk does.
   / Bush Hog Help #13
I've used a LITTLE heat from a hand held propane torch and a three pound sledge hammer with some success. That's after it sat for two days soaking in WD40.
All my neighbors, within tractor driving distance, own their own units so loaning out has never been a problem.
   / Bush Hog Help #14
im kind of confused, do the round shaft gear boxes, that round shaft that comes out of the gear box like the pinion shaft of a car rear end, that the drive shaft yoke goes over, does that shaft a have clip on the end that keeps the drive shaft from coming off at the gear box when the bolt is removed? thanks rob
Need more info, what is the problem?
Are you taking it apart?
Do you mean the shear bolt?
Here is one type of gearbox, it has a retaining ring #21:
2005 Military Trailer (A53424)
2005 Military...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
