Bush Hog Gearbox
/ Bush Hog Gearbox #1
r2heisch
Kubota MX5000
I'm trying to remove the gearbox on an old Bush Hog RB60S. I'm able to remove all but two bolts, both on the backside of the gearbox. They run up from the mounting plate into the gearbox. Problem is there is not enough vertical clearance for a socket and not enough horizontal clearance for a wrench. And my box-end ratchet won't fit around the bolt head. The only thing that I can think to do is to cut off the tail wheel bracket to get the horizontal clearance that I need. I REALLY don't want to do that! Any other suggestion?
/ Bush Hog Gearbox #2
A ratcheting box end of the correct size should work on that, you might try an obstruction wrench. If the tailwheel bracket is welded on, it would be easier to take a hole saw and cut an access hole in the deck so you can get at it from underneath with a socket and extension.
/ Bush Hog Gearbox #3
How about with a cutting torch and some skill, cut the side off that nut and knock it off. Tractor supply got plenty of them
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
2007 50FT T/A 3 CAR HAULER TRAILER (A59914)
2007 50FT T/A 3...
John Deere 620 Quick Attach Loader with Bucket (A65640)
John Deere 620...
2017 INTERNATIONAL LF687 DAYCAB (A65643)
2017 INTERNATIONAL...
2019 Kawasaki Mule 4010 EPS (A62613)
2019 Kawasaki Mule...
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
