Canitbfixed
- Joined
- Sep 1, 2021
- Messages
- 2
- Tractor
- Kubota L3400
Never looked inside of a gearbox like is on my bush hog, but would it ruin it to be mounted sideways to make a right angle gear box?
I suspect that the vent plug needs to be generally connected to the air space in the gear box. If you flip the gear box upside down and just make it so the vent plug is extended to be on top, oil could dribble out any time heat increased because the base of this new vent tube would be full of oil and an increase in pressure in the gear chamber would shove more oil into it; if the tube is long enough to expand without dribbling it would merely be a weak liability (catching stuff on it and breaking off the vent tube and/or threads at the gear box) instead of a constant mess.I imagine that on most you could “extend” the vent plug with a threaded elbow and some pipe fittings so the vent stays on “top” .
That doesn't work if the entry point is submerged.I imagine that on most you could “extend” the vent plug with a threaded elbow and some pipe fittings so the vent stays on “top” .
Yes, it would work, especially if the vertical portion which is above the lube level had sufficient volume to handle the expansion, you may even avoid leaking lube during expansion. However, that tube would be a serious weak spot for that gearbox. I could see it working for a while but at some point something's going to hook onto that breather tube and break it off, and it could damage the threads of the gearbox where it's attached. I'd definitely look for an alternative for anything other than proof-of-concept.Good points on why this may not work if submerged. I stand corrected.
…but if the volume of oil and air expansion in the gear box is less than the volume of the extension tube, won’t that still limit the pressure that can build in the gear box that can blow out the seals? (i.e. limits the pressure to the “head” of the tube?) Worse case it pushes some oil out of the tube and not the seals?
