Rotary Cutter Bush Hog Gear Box Leaking
   / Bush Hog Gear Box Leaking #31
Yes. It was still residual oily/greasy but no reserve bulk. Maybe I added too much oil, but I tried to err on the low side. Maybe the grease thickener was incompatible with the gear oil. :unsure:
Yes, but did you mix the two together before it went in gearbox?
   / Bush Hog Gear Box Leaking #32
   / Bush Hog Gear Box Leaking #33
Sawer Rob, Off topic some, but, how do you keep your cutter from digging in during frontward pulls? I have a Woods BB60 and unless I drive in reverse it will surely dig in on one side or the other and leave a gouge in my clay soil?
I need to "constantly" watch the front edges and make adjustments if going forwards! It's easiest to just drive backwards - although very hard on the neck!!
Your ground does look flat and mine has nooks-n-crannies but I wonder if there is some trick that I haven't yet discovered. Thanks Greg
referring to your post#27
   / Bush Hog Gear Box Leaking #34
Position control on the 3 point, I set it so the front of the cutter is a couple/three inches off the ground.
SR
   / Bush Hog Gear Box Leaking #35
Is your TYM rear wheel stance narrow in comparison to the width of the bushog? That accentuates l/r leans.
   / Bush Hog Gear Box Leaking #37
Im not sure what question remains unanswered in the posts. There was only a little grease - oil patina left coating the inside of the gearbox as in post 29.
   / Bush Hog Gear Box Leaking #38
FYI: IMA, the first thing to check on a leaking gearbox is that the gearbox breather can actually breath and isn’t plugged. Especially if it weeps on sunny days.
   / Bush Hog Gear Box Leaking #39
Spyderlk, Not really, my BB60 is about 1-2" wider than my rear wheels and it will gouge (rather than slide on top of) the ground even if I'm going straight. I need to be "constantly" keeping eyes on it to not have it snag a chunk of ground. However if I cut going backwards it does just fine. Yet that's real tough on my neck!
I try to keep the front of the cutter about 1-2" above the ground when going forwards but - go through a dip in the ground - and it "always" snags the ground rather than skim on top. I just wondered if I was doing something wrong whilst operating it? The manual doesn't cover operating much. Thanks
   / Bush Hog Gear Box Leaking #40
IF you have the cutter leveled side to side, and the front is a couple inches off the ground, and you expect it to "never" scrape the ground, then you are using the wrong cutter.
It's a "field" mower, not a "lawn" mower with anti scalp wheels on it!
SR
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
2013 International WorkStar 7500 T/A Altec D3060BTR Insulated Digger Derrick Truck (A55973)
2013 International...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
2015 Ford Explorer XLT 4X4 SUV (A56859)
2015 Ford Explorer...
24017 (A56859)
24017 (A56859)
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
