Bush Hog for YM2000
   / Bush Hog for YM2000 #1
Jamester
Memphis, Tennessee
Yanmar YM2000
what would be the biggest size bush hog suggested for the YM2000????
   / Bush Hog for YM2000 #2
5' maximum and you can bog down with that in heavy stuff. Using it with common sense will work fine.
Thanks Winston, I found a decent 4ft, but I do have about 2 acres of HEAVY stuff that I need to get cut
   / Bush Hog for YM2000 #4
For heavy cutting the 4' would be a better fit.
   / Bush Hog for YM2000 #6
I probably could run a 6 footer. But because most times I cut thick stuff. I run a 5 footer. I can bog my engine down with the 5 footer
   / Bush Hog for YM2000 #7
I have a ym2000 I also own a 4 and 5 ft Bush hog. In very thick stuff you can overload a 5 footer in 6th gear and have to go to 5th. With the 4 footer you can run 7th gear all day in all but the thickest stuff and then you can almost run 6th gear in very thick stuff with the 4ft. I leave the 5 connected now and if it gets thick I just only take a 4ft bite.
   / Bush Hog for YM2000 #9
Thanx guys
Choosing a bush hog for a ym2000 involves more than how big of hog the tractor will run. The engine might be able to run a five or six footer but the physical size and weight of a five or six overloads the tractor. Even with a five footer you will need weight to keep the front end down in certain situations. A four footer is a much better compromise and when the day is done, you will have cut just about as much.
I decided to go with the 4 footer, it seems like all around, the smartest, best, as well as, the most practical decision for me at this point. thanks for all of the input guys.
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A52128)
2018 Ram 3500...
Online Buyers Premium (A47384)
Online Buyers...
2018 TAKEUCHI TB240 EXCAVATOR (A51242)
2018 TAKEUCHI...
