Bush hog for YM1900
   / Bush hog for YM1900 #1
slynnjr
Dunlap, TN
Yanmar YM 1900
Can anyone suggest a size and brand name of a good bush hog for my YM1900? I will be using it to keep the woods at bay (mountain laurel and small brush) around my house and pond (about 13 acres). I guess I want the most torque I can get. Is there a better brand than others? Is there a name brand that is ideal for YM 1900s and that won't keep catching on the AG tires I have? Thanks in advance.
   / Bush hog for YM1900 #2
I would put a 4' on it.
Danny
   / Bush hog for YM1900 #3
Can anyone suggest a size and brand name of a good bush hog for my YM1900? .......that won't keep catching on the AG tires I have? Thanks in advance.
I've used a Howse Med. 4' RC on my 1610D and my 2010D. Unit perfomed well to saplings of 1.5" or so. Performed well on 1610, better on 2010; 2010 feels like it might be able to go a 5 RC', but the 4' fits the tractor well, and lets me get into the tight woods I have.
The KK 4' RC units I've seen seem as well made as the Howse if not better. Landpride and BH look like even heavier models, but there are many good makes for RC. I'd just avoid off brands.
To keep from catching on your tires, make sure your sway/check chains are correctly adjusted. snug is safer. And I'd recommend chains,if you can afford them or can fab them up. It does raise the price a bit, but if you're working near people or buildings (100') it's required.
Thanks a ton guys, this really helps a lot.
   / Bush hog for YM1900 #5
Like several others, I'd suggest a 4' model.
My Howse cutter has served me well and the only complaint I have is I suspect the gear box uses straight cut gears, noisy. I don't have any brush or saplings to deal with. My 5' model on my tractor is an easy load, I almost don't know it's back there power wise.
   / Bush hog for YM1900 #6
I have a 4' on my 1700 and itt works well. With a 5' it will probably be wider than the tractor. You will have to be careful about hitting things too.
2015 INTERNATIONAL PROSTAR (A53843)
2015 INTERNATIONAL...
2014 GENIE GS-2632 ELECTRIC SCISSOR LIFT (A53843)
2014 GENIE GS-2632...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
CABINET (A53843)
CABINET (A53843)
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
40ft 10-Door Shipping Container (A52377)
40ft 10-Door...
