bush hog for 2015HST Mahindra
   / bush hog for 2015HST Mahindra #1
crackercap
I have a 2015HST and I need to get a bush hog for it, will it handle a 5' or should I stay with a 4'? Any feedback will be appreciated.
   / bush hog for 2015HST Mahindra #2
I have customers who have run 5' rotary cutters on the 2015 HST, and it has worked fine. I think if you are going to be getting into some really heavy brush the 4' may be a better bet. The 4' is Mahindra's recomendation. Good Luck with your choice.
GLaWall
Your Mahindra Tractor Dealer
Batavia, NY
Thanks for your input, that was kind of along my thinking also
   / bush hog for 2015HST Mahindra #4
crackercap, I recently purchased a 4' International BH for my CubCadet 7234, basically the same tractor as the gear 2615 Mahindra only in yellow and 3 less HP. I have lots of trees and hilly uneven ground and I felt the 4' would be much easier to maneuver around trees and slopes. Your 2015 is a smaller tractor and although it may pick up and run a 5' on flat terrain I would think that a 4 footer would me much safer and easier on the tractor. My opinion only.
   / bush hog for 2015HST Mahindra #5
I have to agree with the others. I have a 2015 on the lot (with a woods loader installed) and with the HST. In rough terrain and brush, a 48" cutter would be a good match. Down here, when working heavy cutters, the HST tends to run the oil a bit hot. A smaller cutter would give your HST pump a bit of a break and add to its life.
Just an opinion, I have no solid data on this at this time....
Tractor Tom
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
1996 International Bucket Truck (A50323)
1996 International...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
Kubota B7100 Tractor (RUNS) (A50774)
Kubota B7100...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
